Are any of the coatings able to be applied on sunny days? I'm also thinking of coating my DDs (mine and wife's) down the road, but no garage or the like. The few I've investigated so far all say "cool, out of direct sunlight". Thanks!
I will say this on the Glosscoat.
Good luck covering a 4 door long pickup truck with a cap with only 10cc.
Meh, gloss coat goes a LONG way. I'd say you could easily so a whole SUV plus wheels and barrels on 10cc.
The price and quantity is pushing me towards BF's new coating. Once coated what is the process for bug and tar removal? Is the coating affected by bug nd tr chemicals like selants and waxes are?
i can agree with this.
And speaking of cover:10 cc is 1/3 of an ounce. Can this be true? Do coatings cover that well?
they vary. Gloss-Coat seems to go A LOT further than Pro, for instance. technique and applicator have something to do with it too. if you use neoprene, it will hold onto very little coating. if you use microsuedes, they will hold onto some, but not nearly as much as foam, which is the default included applicator with GC. i actually am not mad at the stock foam pads anymore once i realized that once it's primed, it's primed and holds onto product which can be coaxed out with technique but you only really need to add a little bit here and there as you go along. neoprene works well and is way more sparing overall but it's not flexible enough so it needs to be cut into something with angles imo. the angled microsuede "sandwich" applicator that OPT released seems like the best of both worlds.
i found Gloss-Coat to be way more efficient than 2.0...and 2.0 more so than Pro. if you use the foam applicator, once the pad is primed with Gloss-Coat, you only need a little bit per panel after that and that "little bit" seems to go a lot further than Pro. in before Kyle Allen says mockingly "only a few drops per panel"![]()
Can a coating be put on in sun light yes because I have done it but you have to move fast because coatings flash way too fast in the sun.
Find some shade and you will be ok with the validating application.
HA! I used 30ml of CQUK on my wheels! "A FEW drops per panel" LOL...........
