ewww worm water! jkshake it or keep in worm water for few minutes
ha ha...worm
Anyway, yeah I've only used it ONCE so far because I recently picked up a bottle for $7. Great price. Click on my 'winter GTI' thread. The 2 shots with the hose water is after 2 months. Granted this is Florida winter but still-water sheeting after 2 months on a daily driver is more than I've experienced with more costly waxes. The looks aren't bad either!
Umm, where did you get this for only $7, I'd like to know.
They also sell Aquapel I think $4 or $4.99 each.Harbor Freight Tool store carries both the 845 IW as well as the 476 paste. One was $7 and one was $9.
I throw the applicator away. I also throw the applicator way after using dg 501 it just doesn't come clean.
True and feasible if using a cheaper $1.00 type applicator. I did dedicate a pad for Collinite as I do for other products I use. It may be more expensive this way, but it reduces the chances or cross-contamination and compromising the properties of the cleaner or waxes you use.
In my case, I am using the Polishing Pal white pad, and if you know anything about the Polishing Pal and the pads it uses, they are not cheap.
:whs:agreed. i was referring to the yellow foam applicators in my case. if i use a microfiber applicator and it can be reused i put it in a ziplock bag and label it.
