Hello,
I've taken so much from AGO these past few weeks, I suppose it's time to give back.
Used Collie #845 a couple of weeks ago....
TEMP: 75 degrees/60% Humidity
Application: Hand, Foam
Garage
1 week prior: 2 Bucket Wash/Clayed/Paint Corrected.
Used UQD to wipe light dust prior to application.
Plopped Collie in an Ice Bucket filled with warm/hot water for 10-15 min then shook the bejeezus out of her...then shook it some more. Transferred about 3 ounces, per Nicks recs, to a Meg's self cleaning bottle. Closed the parent bottle tightly and I'll see her in another 3 years LOL.
Special Note: I'm degreed in Biochemistry and Direct Sunlight reacts havoc with some Bio-molecules. Am I saying not to put the bottle in Direct Sunlight to heat it up....Nope; but why even play around when warm water does the trick.
Was Paranoid with the wax from reviewing thousands of post on various forums (you guys know what I mean
rops
so I called Collie Customer Service, The 3 Biggies:
1. Properly Prepared Paint
2. Thin Thin Thin
3. Quality Microfiber for removal <--- He Stressed this. He also advised after your done removing, to go ahead and go over it again slowly/deliberately with a New MF.
Eagle Edgeless MF is by far the best, just MHO.
Watched a U tube video where a Professional Detailer was going on and on about 845 and preached THIN. Then proceeded to apply it Peanut butter style with a Microfiber Applicator, LOL.
What does "THIN" actually mean for cryin out loud?
So go ahead and put it on thin.
Had the Collie by my side and just spritzed the applicator with distilled water and put 3 pea sized drops on the Applicator. Did a quick serpent on half the hood and spread it out "Thin". I only needed two pea sized drops for each section on the rest of the car.
After the hood and 1/4 panel, I did the finger test but she smeared. Waited for 20 minutes and she looked liked it hazed but it still smeared....so "Got It". Did the rest of the car, then finger tested the hood...still smeared. Let her sit in the garage for another 90 min or so then....she WIPED RIGHT OFF, No Problems. Total roughly 2 hours.
She looked pretty good....I wasn't prepared for the Eye Popper when I check her in the Morning.......
WOW!!! Is all I can say. Oh and she wiped off of everything (Trim ect)
So I said 1 scoop was pretty good; hmmm, how bout 2 scoops? Remebered them saying 12-18 hour cure time then layer; so away I went. This time "Primed" the Applicator with a little Collie the squeezed it all the way through and used 2 pea sized drops for each section.
I'm retired military (old soldier) and remember quite vividly "SPIT SHINING" my boots thousands of times; Procedure: IPA Strip, Polish, Wax.....sound familiar? The KEY ingredient....ICE WATER!!! So feeling pretty cocky @ this point, threw that spray bottle of distilled water into the freezer :xyxthumbs: Took it out a little early cause I didn't want a Brick and while I removed the wax spritzed that Ice Water on her. She shined up like a New Penny but I knew to prepare myself for the next morning...I could hardly sleep lol. Well, you see her in the pics above and they don't do her justice let me tell ya. The neighbors were doing the "Double Take"...one that was driving by nearly crashed (No Joke).
I know "SHINE" comes from Polishing...@ least 95-98% and wax/sealants protect...who you gonna leave that last 2-5% too?
Grab some Collie with Confidence and don't look back.
From the shell and feel of my car, she may be able to withstand a limited engagement Thermo-Nuclear War.
Update: she got a quick downpour on her before I hit the garage yesterday...and the water that didn't bead in tiny droplets literally JUMPED off the car!!
Hope it helps
