davidc
- May 6, 2007
- 1,499
I posted this on Autopia also.
I had some questions regarding Collinite products, so I went to the source.
Questions:
I have used sealants ie. Zaino, Duragloss for a lot of years as Carnuba products have not lasted very long especially in the Phoenix area where ambient temps can range from 110-120. Sheet metal can range from 140-180. With all the rave reviews I decided to try your products. I completely cleaned the paint on my Wife's van that is a Desert Sand color and applied 3 coats of 845. I am working on the Gel Coat RV and applying 925, and have also purchased 920. The gel Coat is prestine at this time as I have already done the 3M Super Duty and Duragloss treatment, I am doing the 925 over DG sealants in hopes of warding away the typical oxidation. I have just ordered 476 and 885 to try those also. The main question I have is that I use Duragloss 932 with Aqua Wax which is a rinseless wash and adds sealant. Will this in any way affect your products if I continue doing this instead of a traditional wash. Can I add 476 and 885 over 845 and 925 with ou t compromising durability.
Thank you for your time and so far using only the 845 and 925 they appear to be excellent products and I will test the durability in the Desert as it is already in the 90's and will only go up. The monsoons here start around mid July and end some time in September with dust, rain and then the Sun. It will make for a good torture test. I really hope all of this Collinite hype is real as I would truly like it to succeed.
Dave
Answer:
Dave,
Thanks for the email. The rinseless wash should not affect the durability of the wax and adding the paste wax over the liquid wont compromise durability. Please let me know how the waxes hold up in your conditions and thanks for using Collinite.
-Mark
I know you guys use Collinite to ward off the winter salt. sand and brine. I am going to give it a try with the other extreme. I will try this coming weekend to 476 the hood, roof and rear hatch of the van and time permitting maybe the rest. I will also attempt 885 on the back of the RV, the Drivers side was just 925ed.
Questions:
Dave
Answer:
Dave,
-Mark
