DETAILROOKIE
- Jan 19, 2016
- 1,214
- 163
Thank you for this information, but why does a smaller pad require a higher RPM? I was under the impression that it is the opposite, or is that only for DA polishers? I noticed the Flex Kompact has a minimum of 1300RPM I believe and I always wondered but it was set so high.To me yes the lower RPMs matter. For you learning on 450 is better than 600. When buffing edges or high spots, I like to take it easy so being able to keep the triggerlock on and work at 450 is valuable to me. The Flex will go lower than 600 if you throttle the trigger but the trigger isn’t as precise or comfortable as the Rupes. Jeweling I do like to do at the 450 RPM range if the paint reacts to it well. Sometimes I will bump it up to 600 or maybe 750 but having the option to go to 450 is great.
Just so you are aware the 450/600 speeds are on the trigger lock. Both machines go slower but I like to work with the trigger lock ON As much as possible so I con concentrate on what I am doing. Make sense??
To add: the lower RPM doesn’t matter to me when using smaller 2 or 3 inch pads as you will want higher RPMs for those but when getting to 5 inch or bigger pads it matters to me personally!
This is a new world to me and I want to make sure I get all of the information possible before I delve in.
Sent from my SM-N950U using Autogeekonline mobile app
