Hi I was curious about the advantages or importance of Wetsanding when doing paint correction, particularly with RIDS.
Is it something that can be skipped, or are there times when it should be strongly preferred before polishing?
thanks
What are you working on?
:dunno:
Wet sanding (or maybe it's just the extra step) is a little scary for me tooIf I had a RID that could not be removed with a reasonable ammount of compounding, I think I'd leave it for the reasons Lawrence mentioned.
Honestly, the idea of wetsanding scares me. If I was well practiced in the technique and working on a show car with a known paint thickness, I might go for it. Otherwise, I'd do my best to minimize the RID and move on. Rather safe than sorry.
I'm going to be working on a 2014 Altima. This will be the first time using anything abrasive.
Will be my 1st time potentially doing either one (compounding/wet sanding). I previously used a non abrasive cleaner polish with a microfiber applicator. I did have two prior RIDS buffed out at the Bodyshop that worked on my car.This is the first time performing anything abrasive on the car?
Define first time using abrasive. First time compounding or first time sanding?
Very very impressive! That looks great! I have been considering recording or taking pictures of my progress. I told my coworkers about this lol and they looked at me like I was crazy and needed an intervention.With Mike's help, I wetsanded the sides of my 2014 vette that had pretty bad orange peel. Tried the velvet and denim carpro OP pads, no luck. I stayed away from edges and just used 3000 grit to knock the tops off and REDUCE it, I did not get rid of it, too dangerous to eliminate. It went well, I followed with several polishes, rotary and orbital, (Meg 105/205) and got what I wanted. A paint thickness meter showed I took of a bit but not too much. I followed with CquartzUK to add a bit of thickness back. Months later it still looks like glass. It took about 20 hours of work.I could have cut a lot of time off by stepping up from 1200, 1500, 2000 then 3000 but I wanted to be overly safe.
the finished look:
the look 7 months later:
another car that did the same:
