I have been playing around a little bit with the wolfgang Fuzion wax. I have 2 jars of it. 1 sample size and 1 full size tub. I am looking to get the application , wait time and removal down pat in my spare time. (sample size was purchased to be applied with my PC later down the road, as I would not like to drop the estate sized piece of wax on the floor while rubbing it on my foam buffing pad)
I tried 2 different sections. Both panels have been properly prepped and de-greased. Was was applied in a thin layer with even coverage.
1st section - I applied the wax, than removed it before it dried (or hazed), as per instructions. the wax was for sure not hazed, but it still came off very easily. When i felt the panel with the back of my hand, there was no "just waxed" slick feeling. Which made me questions this application method.
2nd panel - I applied the wax, waited about 7 minutes, but the wax never really fully set up like a traditional wax. at the 10 minute mark, I removed it. This time when i felt the panel with the back of my hand, the surface was fairly slick.
now, I came back 30 minutes later, and both panels feel a much slicker than they originally did after application. making me believe that the wax is still setting up.
Which leads me here. I searched through this entire forum section, and did not see anyone with a similar question as to mine.
My question is, can anyone explain to me the best way to apply this wax ? and is there any noticeable difference in looks and durability if I was to stray away from the recommended instructions on the tub and let the wax sit for 10 or 15 minutes or so ? If not, I will just stick to the WOWO method.
How are you guys with a lot of experience with this wax, applying and removing it ?
thank you.
thank you.
