condoms melted on paint??
If they were lambskin ???
Use a Sheepskin or Wool Wash Mitt !!!!!!!!!!
Very possible solution...(Like against Like)!! :props:
Then...Latex gloves vs. Latex condoms?
Vegan (what?) vs. Vegan Condoms?
100% Cotton wash mitt vs. 100% Cotton sock? (<<<in my case over-the-calf tube socks)
Make sure to wear gloves whatever you do...
Take a towel soaked with mineral spirits and sit it on the latex for a minute (assuming you're working in the shade) and then try wiping it into the towel then trash the towel and clay as normal.
This is a good idea, another idea is to mix up some car wash solution, (you're probably going to do this anyway to wash the car), and then instead of using mineral spirits just wet a wash cloth, microfiber towel or hand towel so it's soaking wet and place a towel directly onto the offending object and let the water and soap solution do it's work by soaking in and softening and loosening everything up.
Like this only start with a wet cloth and then add even more water too it until you have so much water it's running out from the towel...
How to safely remove a dried bird dropping
Now add water to saturate your microfiber but don't add so much that you have water running off the hood. Allow 5-10 minutes to pass so the water can soak into the dried bird dropping in an effort to re-liquefy to make it soft so as to reduce the potential of instilling any swirls and scratches from dried bird dropping being rubbed against the paint.
Now carefully use your hand to scrunch or bunch up the microfiber around the now liquefied bird dropping and then lift the bird dropping up and off the paint. Don't simply wipe the bird dropping over the paint.
Good luck...
Usually I ask forum members to take pictures to document the process to help others in the future but you can skip it this time...
:D
