Confused between Megs Ultimate liquid wax vs NXT 2.0
chaznad
Im an hour away from finishing a clay/compound/polish and im confused about the sealent i should use...I went and bought some ultimate liquid wax after reading reviews and now im reading it streaks... i have a Obsidian black 05 g35 coupe and live in florida , so i just want something that will last , shine and protect with this weather
UW has the better durability and will not stain rubber & plastic trims.
However, there is a bit of a learning curve on the UW. It will streak it you use too much product and/or if you let it dry too long. Meg's recommend 2-3 minutes before wipe off.
Also, if it does streak, just re-apply a bit of UW on the affected area and wipe off.
ok , ill give it a shot then ... Are you using 2 coats ?
great !!! just finished polishing and go to take the ultimate liquid wax out of the package and somebody swapped it with gold class wax , WALMART for ya !!
Now im afraid to drive anywhere because no protection on my car plus i dont want to contaminate it
I usually like to top my sealant with carnauba which by the way is Gold Class Plus in the paste form.
As per Meguiar's, 2 coats of the same wax/sealant is recommended not for any added protection or increased shine, but just to cover any areas you might have missed on the your first coat for uniformity.
