It seems that the more I try to keep the pad as flat as possible against a panel the more the polisher wants to get out of control and then I tense up more which I know is not helping things. This doesn't seem to change much with slower speeds. If I angle polisher slightly it seems to resolve the problem.
I Was given a polishing kit and suspect that the pads and polish are cheap and nasty and wonder if this could affect things? Or maybe I am still applying too much grip pressure trying to keep pad perfectly flat on panel.
Absolutely any advice hugely appreciated
Thank you.
Thank you.
