Thejoyofdriving
- Jun 10, 2007
- 1,166
- Thread starter
- #21
HossAuto said:You can use a screw driver to pry it off, but be slow and very carful (plastic breaks) and pry the hose off slowly working around the plastic piece. I forget if there is a drain or not because i always just pull the hose.
Just to let you know when you install is put the clip back in first before you put it back on the radiator and slide it on as straight as you can. and to bleed out the air just turn the key to the on possition (dont start it yet) it has a electric water pump. and take the bleeder screw out on the upper hose it should be on the engine side of the hose. and before you do all that make sue the radiator is full.
Rich
We tried with a screwdriver but no luck. And how do you get the collant out of the engine block if you just pull the hose?
