We (I and another forum member) essentially follow the guides when detailing our cars, but I am confused about certain things; we need to improve our processes to not require so much time; and we may be needing to use different products that offer greater longevity in the appearance/protection category...
We're talking about 5 cars; one is a garaged `06 that has been 'autogeeked' since new; the other 4 are not garaged, but have been 'autogeeked' at least once. One of the 4 is a black Yukon XL; I kid you not when I say that it takes a solid 2+ days to do an 'in and out' full-on detailing. Mind you, part of this is the 12 hours for the Klasse sealant to set up, but we are working on this thing all day Saturday until about 10 P.M., leaving it set until about 11 A.M. Sunday morning, and following up the Klasse with more stuff, primarily for appearance and what we think is additional protection...
The other cars also require the same two days, although it won't be as late Saturday when the car (and we) get to rest the 12 hours for Klasse to set up.
It takes us so long to do our 5 cars that we don't think we can start a business; we need 5 good-weather weekends to do our cars, and then there's the maintenance washes, quick detailers (as needed), and tire treatments... So with bad weather, we either have to turn away paying customers (not good for business) or ignore our own cars (not good for the pride we have in our vehicles and their appearance). Neither of us has the property necessary to build a workable garage...
Interior
Vacuum...
Clean carpets/seats as necessary...
Clean plastic/vinyl...
Clean glass...
Tried Windex, Stoners Invisible Glass, etc...
Windex usually takes 2 applications, streaky during application, but remains cleaner longer than Stoners...
Stoners usually takes one application, less streaky during use...
Any other candidates worthy of consideration (no night reflections, please)
Apply plastic/vinyl 'sealers' or protectors...
Plastic/Vinyl protectors seem to rub off easily on clothing (glove box/console areas)
Tried DP Total Interior Protectant, Meguiar's, Turtle Wax Formula 2001...
Don't want really bright shine (no night reflections, please)
Recommendations?
Apply seat moisturizers/conditioners...
The `06 we do has suede leather insets in leather seats...
Haven't found non-shoe (those things on your feet; Kiwi is all that we have found) suede cleaners or conditioners...
Recommendations?
Now look at the carpets... vacuum again...
Exterior
Start at the driveway, clean the tires, wheels, etc. first... No problem...
Foam/rinse/foam/wash the vehicle... some say top down (roof to the rocker panels), others say bottom up.... we do top down (keep the heavy dirt closest to the ground)...
Clay bar... here as well, we do top down... Some say clay removes any wax/sealant, others say not... I'm in the 'not' crowd. It may remove wax/sealant from where-ever dirt/impurities are lifted, but not over the whole body of the car (or truck)...
Some say wash again, others say only wash again if no further correction is required... We wash again, regardless...
If no correction is needed, what minimally should be used to strip off the old wax/sealant? Paint Polish? Paint Cleaner? Both, and if so, in which order? We have treated XMT 360 as a cleaner/polish, sealer, and wax... are we off-base?
If I need correction at this point, we'll use XMT 1, 2, or 3 as needed. Any of these will remove wax/sealants and hopefully correct the issue we feel needs to be addressed. However...
If I need to use XMT 3 on a panel, should XMT 3 be used on all panels? We don't...
Do we need to follow this up with a paint cleaner/polish, or another wash?
If I need to use XMT 2 on a panel, should XMT 2 be used on all panels? We don't...
If I need to use XMT 1 on a panel, should XMT 1 be used on all panels? We do; we pretty much treat it as a paint cleaner/polish in one...
How does one assess whether any of the XMT products can remove the visible blemishes? Do you start with 1 and work your way through the line until the blemish is gone, or how can you assess the blemish and treat it with the right product the first time? How do you determine the difference in XMT 2 on a heavy-cut pad verses XMT 3 on a low or medium cut pad? Obviously, experience helps, but right now we (myself and another forum member) detail 5 family cars, usually together. It could take many months to get to that point of understanding and experience; we need help..
Apply Klasse...
Top it with one or more coats of wax... Usually from the Sovereign family, and occasionally followed up with OptiSeal...
'Back to Black' on various external plastics/moldings...
'Never Dull' on chrome...
DP Wheel Glaze...
DP Tire Gel...
Any improvements, suggestions, anything that leads to a constructive and positive resolve would be greatly appreciated. We'd really like some of our life back to rest and relax; we both immensely enjoy working on the cars, but there must be something more to life than working Monday - Friday, then working on cars Saturday - Sunday, and not really getting to enjoy anything else...
Feed back please
Interior
Vacuum...
Clean glass...
Recommendations?
Recommendations?
Exterior
Apply Klasse...
DP Wheel Glaze...
DP Tire Gel...
Feed back please
