heavychevy
- Nov 7, 2006
- 26
PC vs Vette = WWII, I am having a tough time even with a rotary but I can get all the swirls out but cant get a perfect finish (with flashlight looking from about 3-4 in). I am practicing on a spare hood I have from my vette. I would advise the XMT 3 on a orange pad speed 6 followed by XMT 1 on a white pad speed 6 LOTS OF PRESSURE keep this up until you have very small miro marring. Then you should try a finishing polish on a gray pad (very important) and then use XMT glaze with pinnacle souveran with a blue pad. Pinnacle Souveran doesnt do JACK for swirls. At least the glaze can cover those babies up.
You want some cut and then the gray and white pads are your best friends.
If you expect some real results on that car with a PC Optimum should be in your line-up as well (at least the comound and polish)
More importantly
1 Move Slow Very Slow
2 Check your work repeatedly
3 Swirl marks have a long side and a short side, or if caused by a machine are still round move perpendicular to the long sides or in a different direction than ther swirls (go across them not with them) in STRAIGHT LINES.
4 LOTS OF PRESSURE!!!!! ( push that baby down hard, the PC can generate some good heat when you push her real hard
this is the best I have been able to do with a rotary on vette clear. you can get rid of the swirls but the micro marring left behind is a @#^& to get back out as well.
More importantly
