CQUARTZ Leather Coating
medicscott
So I need to protect these 2013 Mercedes seats this weekend for a customer and saw the ton of dots/holes in the seats. Anyone have experience doing an interior coating on these types of seats? Does the barrier of protection dry over the hole making it an eye sore? Welcome your thoughts on how this will look after its finished.
***BUMP***
Avi, Anyone?
Don't want to apply this stuff and have a mess on my hands when it dries with possible product cracking, etc in-between the holes...surely someone has used CQUARTZ Interior on a Benz, No?
Have not used it, but I would imagine it would be fine for a perforated coated leather. Most leather has perforation of some sort, or at least stitching.
From CarPro's product description page:
Avoid use on white finishes
Directions:
Thoroughly clean all dirt, moisture, and oils from surface with non-oily, interior safe cleaner - (Recommended Ultima Interior Shampoo Gel)
Wipe with a water damp towel to remove residue from your cleaner if needed
Pour at least 10 drops or one small strip onto the suede wrapped applicator
Work CQuartz Leather & Vinyl into the surface including all creases, and texture
Gently wipe off any excess within 2-3 minutes
May layer after 30 minutes from start of the first application
Touch dry after 10 min / Avoid water for 4 hours / Fully cured at 3 days
Edit: Or listen to someone who has used it like below.
Maybe try to be cautious not to over apply if that's all you have on hand
I never had good luck with it, try the Gyeon, wipes on easy, no clogged holes or residue left, nice matte finish.
Yes, I coated a new Macan, it had basically white leather and it was perforated. It is a great product.
HUMP
Todd at Pureshine has been using it for a while now if I recall correctly.....he may have some good info and chime in on it!
Mike
***BUMP***
Avi, Anyone?
Hi, there will be no problem at all even with these holes, the coat is thin, flexible and even breathable over the leather surface. it dries almost instantly and doesnt get solid or crack.
after applying , and minute after , if you see high spots just wipe them off gently with MF. driver seat i would do 2 layers minimum, let it dry well before you seat on the leather after. follow the instructions we publish, either on Carpro US site or on Autogeek.
Thanks Avi, and everyone else for your feedback, it is greatly appreciated. Order arrives on Thursday just in time for my detail.
[video=youtube_share;2hHHA2WPJv0"]Cquartz Leather coat 2014 - YouTube[/video]
application in the beginning of the video... then excellent testing towards the middle of the video.
-Zach
The folks I know who have used it love it. They rave how great it is so now I offer it as an add on as of last week.
Wonder why the instructions say not to use on white leather?
White leather is more sensitive to UV light,we think that leather manufacturers use different type of clearcoating resins on them,very thin , some use more Anti UV protection and some dont, you see everything on that white , so if the leather use poor leather coat we suggest first to check our coating on inconspicuous area to check the reaction. only then to coat the whole area. HTH
