zmcgovern45
- Sep 5, 2012
- 3,443
A side question.
How long after a fresh re-paint should one wait to apply CQUK?
I'd say the standard minimum of 30 days applies to paint coatings as it does with standard waxes and sealants.
A side question.
Hello
What proccess is it if you want to coat again with cquk but without polishing the car? Lets assume you had cquk for a year on your car?
Just to wash it and then cquk?
But let assume that the car was only washed with reset shampoo and topped with reload.
Then technically after deagresing and washing, the new coat on the old cquk will work?
And of course, its only if you are more interested in protecting the car then its shine.
are you sure?
To be able to coat the car have to be clean, really clean. Is the polish only way to get it "clean" ?
As others have said: Ideally you would do at least a light polish to prep.
But..... If you are washing with Reset and using Reload you could "top up" CQ/CQUK with another layer after a good wash and Decon. I would wash with Reset or IronX soap and then use IronX and TarX . Then do at least 1or2 wipedowns with eraser. Then you would have a clean surface to apply another layer.
Troy, Would a paint cleanser from somebody like Pinnacle or DP work?
I would've maybe thought so, in that a hand application with one of these would maybe clean off any toppers (reload-etc) without adversely affecting a previous laid down coating since there's no abrasives?
Im also asking because a layer with previous 2 coats and then top up with 2coats again would protect more?, and also you save your car paint from polishing?
4coats is better then 2?
I know this topic is a bit old, but wanted to hear from people using the cquk product. I have been normally using polymer sealants, Wolfgang DGS 3.0 being my favorite so far. I apply the sealant to all painted surfaces, metal, glass, and headlights. I was looking at the website for cquk and it mentions paint, metal, headlights and "more" but didn't specifically mention glass. Have you guys been applying it to the glass also? I have the Wolfgang ceramic coating I'm going to be applying to my truck, but detail my buddy's trucks and he bought the cquk product and wants to use that.
