HateSwirls
- Jun 24, 2013
- 3,632
I can do an entire interior with now two refills, IMO that's not bad.
The McCulloch is a beast for the price
I have the therma kleen 1.5 and love it. it does a great job cleaning leather and getting stains out of the carpet. during the winter months I use it on the exterior of my car and it does a decent job. the staff there is friendly and great to work with. I was using the tornador before I got the steamer and thought it was perfect. but the steamer just seems like it does a better job and there is no over spray mess.
This video is from my most detail using my steam cleaner.
How To Clean Upholstery: Hot Water Extraction - Critical Details Premium Automotive Detailing - YouTube
I bought a Daimer 300CS a few weeks ago. I'm still getting used to it. The shop I worked out before never used steam and I wanted to make it apart of my detailing regiment. Any advice you can give on using steam? I heard not to use it on vinyl as it can gray the material or use around electronics. I really think we should have a steam cleaning thread discussing all the different uses and techniques!
You may run into an issue on vehicles that use vinyl to cover up the hard plastic interior surfaces. I am talking about the material that is always pealing off of MK4 Volkswagen interiors if you aren't familiar with it. Another moisture sensitive area is the headliner. I try to steam clean the headliner in sections allowing one area to cool/dry before adding more heat/moisture. If you get encounter a stubborn spot on the headliner don't keep working on it until the stain is fully remove. After you use the steam cleaner for a while you will start to learn what it can and can't safely remove. It isn't worth removing a stain 100% if it's going to compromise the headliners adhesive.
I am always careful around electronics and will spray steam into a microfiber towel before wiping down the radio/navigation part of the dash. Just like how you would spray APC into a microfiber towel when cleaning sensitive areas.
Always keep the steam cleaner moving like you would a rotary buffer. Too much heat in one area is a recipe for disaster. When you are using the concentrator nozzle be sure to have the tip pointed away from you or sensitive materials when pressing/releasing the trigger. Extremely hot condensation builds up in the hose and will instantly burn you if you aren't careful. I have been using my steam cleaner for three years and still burn myself once in a while when releasing the trigger.
The only thing that I don't use my steam cleaner for is cleaning exterior paint.
Thanks :dblthumb2: I know exactly what your are talking about regarding the vw interior. I have an Mk4 and the plastic has been peeling for years (this is before I had steam). Everyone I know with a vw has the same peeling issue as well. I picked up Renny Doyle's video about steamers. It helped to get an idea of the different uses for steam.
Two of my favorite uses for steam are cleaning cup holders and door jambs.
I like to squirt a few sprays of Optimum Power Clean diluted 6/1 into the cup holder and cover it with a microfiber towel. Then insert the steam concentrator nozzle into the cup holder and melt away all the built up grime. The microfiber towel helps keep the heat in to quickly dissolve any coffee residue or melted candy. In addition the towel keeps the cup holders unwanted contents from being blasted to other parts of the vehicle and making an even bigger mess.
For door jambs I like to liberally apply Optimum Power Clean diluted 3/1 and let dwell for a minute or two. Then use the steam cleaner on max pressure to remove any dirt and debris. If the door jamb is greasy it is a good idea to put a microfiber towel below the hinges to prevent making a bigger mess. There is nothing worse than having to polish the rocker panels because the door jamb sludge stained them.
Thanks for the info. do you use the steamer on engine details?
What do you flush your steamer with?
Not sure if this is the exact thread I was reading but there are some members discussing CLR
http://www.autogeekonline.net/forum/auto-detailing-101/72322-how-descale-steam-cleaner.html
Thanks for information. I have only had my machine for a few weeks now. I have only used it a handful of times. I read the manual and it did say it could use tap but I think I'll use distilled water from now own. I'll pick up a bunch of gallons at once to save on the trips. The steamer wouldn't use that much distilled water but my Mytee extractor seems like it would over time.
I just went down and emptied the bottom drain. There was still some water inside. Should I be emptying the steamer after each use from the bottom drain. I thought I read in the manual to drain it from the top opening and use the bottom drain for flushing the system. I have to re-read the manual. Water was clear. So to clean the system just let distilled water sit in it for a few hours?
I'm not sure if that is the same thread I was reading but I knew I had come across a few threads of member discussing using CLR to clean out the calcium. But I can't seem to find those threads when searching.
Thanks for great information:dblthumb2:
Is calcium in all water? I know the water here is not hard but not sure if that matters
