Andr3wilson
- May 16, 2012
- 1,615
Forgot to mention, you should also figure out what your product cost/ vehicle is. This comes with experience, but it is a very important thing to know.
Attention To Detail is all about restoring your car to like-new condition. There are several options, all depending on what your car specifically requires. Anything from a wash and wax to full paint corrections that most detailers charge $65+ per hour for. Feel free to research the average cost for paint corrections before deciding, all prices listed below are very competitive for clients.
Owners can receive photo/message updates if requested.
>>> Subtractions from the total cost can be made for clients travelling from farther distances
Mobile Detailing :
For jobs that can be finished in a single day, the work can be done at client's residence given that gas there and back is paid for (if the location is more than 50 miles away). No extra charges, travel fee is calculated by mileage to residence & back.
$20 referrer pay for referrals when total comes to $200+
Packages (Prices listed are for average sized vehicles)
* Times vary depending on condition of the vehicle and the work it requires, no vehicle is exactly the same.
More information about all packages can be given at request
Exterior Detail and Wax - $100
The vehicle is debugged and pre-soaked with a foam cannon using citrus wash to remove any previously applied wax, then hand washed and followed by a clay bar treatment. Premium wax is applied by machine or hand to protect the finish and give it a nice shine.
* Note that clay barring removes all surface bonded contaminants which keep the finish from being completely smooth to the touch. It also helps the wax bond to the paint which enhances the shine and provides longer protection.
Interior Detail - Starting at $80
Entire interior of vehicle is vacuumed (steamed/vacuumed if needed) . Floor and trunk mats removed for steam cleaning, all trim is wiped down and protected including dashboard, door panels, compartments, ash trays, instruments, knobs, and air vents. All glass is cleaned inside and out.
Exterior Detail and Wax + Interior Detail - Starting at $150
All steps from the two packages listed above followed.
Exterior Detail + 1 step correction - Starting at $215
Once the vehicle is washed + fully decontaminated, the paint is treated with a 1 step correction process to remove most minor swirls from the paint. The correction is then followed by premium sealant and wax.
Exterior Detail + 2-step Correction - Starting at $290
All steps from previous packages used + two step correction process to remove more severe imperfections. The process is then followed by premium sealant and wax.
Exterior Detail + 3-step Correction - Starting at $350
This is the mother of all exterior packages. Again, all steps previously listed will be followed, and then most, if not all exterior imperfections will be removed with the 3 step correction process. Followed by premium sealant & wax.
Engine Bay Detail - $30
All electrical components are protected beforehand. The entire engine bay is degreased + wiped/scrubbed with various utensils, followed by a thorough rinsing. All plastics and metal are shined + protected.
Complete Detail + Correction -
Package with 1-step starting at $300
Package with 2-step starting at $360
Package with 3-step starting at $420
Exterior imperfections removed with the chosen paint correction process, and then the interior and engine bay are meticulously treated to bring your car to showroom condition.
Complete Exterior Wet Sanding Correction - Starting at $650
(A few days will be needed to perform this correction)
This is for vehicles with severe "orange peel" and other imperfections. The paint is first wet sanded with very fine sandpaper, and then polished back to a showroom finish. The paint is measured frequently throughout the process. Followed by premium sealant & wax.
Coating - $175
Say goodbye to having to wax your car! With Opti-Coat 2.0 you will never have to wax your car again. After the coating cures, it is permanently bonded to your paint giving it a freshly waxed look. Unlike a wax or sealant, Opti-Coat will not wash or wear off. OC needs to cure for 24 hours before being exposed to the elements.
Other Services :
Headlight/taillight restoration - $35/ea (done by the set, i.e. both headlights/both taillights).
Removes yellowing/fading, most scratches, guaranteed to last. If imperfections return, lights will be re-restored free of charge.
