03Mustanger
- Nov 30, 2014
- 31
Searched for this topic and couldnt find any good results. What are the best or your favorite cutting compounds? As well with what pads do you use with them?Feed back please
I like stuff that cuts great or cuts really well and finishes well.
I use Optimum Hyper Compound, HD Adapt, and HD Cut.
Optimum Hyper Compound was recently reformulated and is now very fast cutting while using very little product and not needing exceeding speeds on the machine.
I find Meguiars Ultimate Compound to have the cut of a medium polish.
For compounding Menzerna FG400 and Rupes Zephir(smells like bubblegum).
Nowadays...
Before using "cutting compounds"...I like to take
into consideration, at the very least, the following:
-How much CC (clear-coat) is available
-How much CC can be removed without compromising
the paint-systems' durability; "UV protectors"; even
the paint warranty.
So:
With OEM paint-systems' top-coat film-layers
(usually CCs) being applied at thinner and
thinner thicknesses...
I find myself contented with only using
"cutting compounds" containing abrasives
graded at the aggressiveness-level of no more
than, say: Meguiar's Ultimate Compound.
Menzerna Fast Gloss Compound, Fast Gloss 400, FG400 compound or Wolfgang Uber Compound, car polish, polishing compound (both made by Menzerna) with 5 Inch Hybrid Power Finish Orange Pad (Single) with Flex XC 3401, FLEX Orbital Polisher,flex XC 3401 VRG dual-action polisher,flex XC3401VRG,Dual Action polisher,FLEX buffer & FLEX XC3401 Changeable Backing Plate System using Mike@DedicatedPerfection's technique http://www.autogeekonline.net/forum...rning-3401-menzerna-products-hybrid-pads.html
I see you recommended a foam cutting pad. Is there an advantage in going with a wool cutting pad or vice versa?
