Dash protectant
Two other products not yet mentioned I've found to provide a nice natural shine are McKee's 37 Interior Surface Protectant and Meguiars Natural Shine Protectant. The Meguiars is only available here in wipes, but can be found elsewhere pretty easily in spray bottles...odd you can't get it that way here.
The Mckee's 37 Interior Surface Protectant is TOP NOTCH! Has been used since my Xterra was new. Dash/plastics still look like new.
CarPro PERL @ 3:1 works great for what I'm looking for (low to medium shine). 4:1 would probably also work great and leave a nice fresh, clean look.
This past weekend I wiped down my interior with some UWW+ mix and then dressed with PERL. Instead of using a Buff and Shine red foam applicator for the PERL though, I sprayed the 3:1 mix on a Meguiars Supreme Shine mf towel to prime and then 1 spray on the area I was working on- it worked PHENOMENAL. The lower nap mf towel allowed for much less product use while yielding a better looking, more even coat in, like, 1/2 the time, if not less. Can't believe I didn't stumble upon this method before.:doh:
I really like it. After getting my hands on a sample, I gave away my bottle of 303 and ordered some in a full size bottle.
I used 5:1 and it was great! I actually like that also on my tires better than full strength.
Sent from my SAMSUNG-SM-G920A using Tapatalk
To this day I still will only use one product on my soft touch VW dash. And surprisingly it's purchased over the counter. Lexol in the blue bottle. Best dash protectant I ever used. Literally been using it since 2006.
I've been using 303 yearly since I got my car over years ago. A single coat does the trick and occasionally I'll wipe the dash and door panels with a damp mf towel from doing a WW wash to remove a little dust and to even things out.
Every so often I'll use McKee's Fast Interior Detailer and it plays well with 303. IMO 303 is a no brainer!
