Daytonna brush ANNOYING splatter!
statusdetailing
Guys, I love the Daytonna wheel brush but I absolutely hate how bad it splatters all over me every time I use it. It does a great job, it's durable, but I've finally just had it with the splatter. I think I'm just going to have to part with the brush and try something new. I usually wear gloves and long sleeves when cleaning wheels. I tried a face shield but I hate using one and it just looks stupid.
What are some good alternatives that you guys are using to clean the inner wheel barrels?
Thanks so much!
Jeremy
lower the speed so you can control the splatter , go in oval or side movement , wear goggle , have an apron
I believe in one of Nick's videos he mentioned to turn the brush as you're pulling it out of the wheel to minimize the splatter.
I love mine and just ordered 2 more on BOGO.
There is no alternatives as far as affectiveness and versatility IMO. Your problem is easily solved, follow these tips and you will enjoy doing wheels again.
1. After your favorite wheel cleaner has been sprayed and is ready to work, use a foam gun and complete soak down the wheel in foam. This will reduce the splatter to zero.
2. If you don't want to use the foam gun for wheels, when your ready to do your barrels, prime the brush with your car shampoo in a foaming bottle, and the splatter will be zero.
3. Use a seperate wash bucket for wheels, and put some car shampoo in it. Get it nice and foamy, and dip your Daytona in it after each wheel.
The common denominator is foam, haha.
You could also use...
Turbo Stick
Wheel Woolies
A bunch of other barrel brushes, but IMO, none are as useful as the Daytona.
Also, I like to have one kept straight and the other bent at a 90 to save time while cleaning to the back of the barrel and the back of the spokes.
maybe you could attach a large disk to the hilt between the brush and handle. might make it more cumbersome, but would block you from a lot of the splatter.
Or maybe stand to the side when you pull it out of holes.
I feel your pain though. I ruined a good shirt using that thing.
I have a Meguires brush that is similar and have found the same splatter with it. I have been wondering if the Daytona would do the same thing and now have confirmation. The good thing about my new Maxima is I can get my hands fully into the barrel and work the wheels with a rag so the brush has been relegated to shelf duty now, at least until warmer weather get here.
Wheel cleaner splatter on the face sucks.
I cut up a milk jug, use the handle portion to hold on to and cut the bottom off and 2 sides.
Foam = no splatter. I haven't gotten splattered since the first time it happened.
I deal with it. There's no other barrel brushes as versatile.
Agreed. Although I still haven't gotten around to purchasing a set of wheel woolies just yet.
Love my daytona & ez detail brushes. :xyxthumbs:
Thanks so much!
Jeremy
The big one is the splatters Queen.
I like the foam gun idea a lot. I'll try it out. Thanks man! :xyxthumbs:
Turbo Stick
Wheel Woolies
No problem man. It will solve your problem, guaranteed. I haven't gotten any splatter since the first time I coated myself with nasty dirt and grime from the wheel. :xyxthumbs:
You guys have encouraged me to try some new techniques to avoid the splatter. Thanks for the advice. Like I said. I love the brush, just not the splatter.
Do you guys like the jr brush for smaller areas? Perhaps that would be a good brush to bend at 90 degrees.
This is what I do (and I never pull it perpendicular to the wheel - always to the side opposite to where I stand)
