Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
Hi. First time poster. I'm in the process of reviving the original single stage paint on my 1966 Chevy pickup. I've been following Mike's regimen using Meguiar's #7 and the results have been good so far. I even was lucky enough to talk to Mike on the phone recently to get some tips on what to do.
Todd!
You're truck is looking awesome!
The paint is coming back nicely. However, the truck has a lot of dings and scratches. Apparently, it lived a very rough life in a mall parking lot somewhere, which is a shame considering it only has 34k miles on the odometer.
Can these scratches and nicks be corrected (or even just made less noticeable) while preserving the original paint? The rest of the paint is pretty good but this "rash" is really bad all up and down both sides at car door height.
Thanks,
Todd
Here's your other two pictures, I uploaded them into your gallery here on AGO so they could be inserted and thus easier for everyone to see and talk about...
If this truck were mine I would run a compound with a foam cutting pad on a rotary buffer over these effected areas to smooth and shmoo them over to start with.
Then in you want to try to touch them up with touch-up paint consider contacting Dr. Color Chip and see what they can do for you as getting a perfect color match.
See my article on how to use their system and please take my word for it... it's as easy to use as I share in the article...
It's also FAST and EASY.
Doing more, like adding touch-up paint, waiting for it to harden then sanding the area then buffing the area then polishing the area "can" work but it can also lead to turning a mole hill into a mountain.
Here's my article. By the way I see the owner of this Mustang all the time and you really can't see any of the touch up paint or more specifically, you can't see where the rock chips were unless you know where to look and get your nose down by the panel and look real hard.
How to use the Dr. ColorChip Paint Chip Repair Systems
Here's post #2 from the above article....
Mike Phillips said:Three simple steps!
Here is a list of the steps you want to follow in this order, below this list I'll go over each step with pictures.
Step 1 - Use IPA or Isopropyl Alcohol with a clean, microfiber towels and gently clean the rock chipped area as best you can. Feel free to improvise for example use a Q-tip swab to really get into the chip and wipe it clean. It's important to have a clean surface for the touch-up paint to adhere.
Step 2 - Shake up the bottle of touch-up paint to ensure a uniform paint mixture. Then after selecting the appropriate brush, dip the end of the brush into the touch-up paint and dab the paint into the rock chip. After dabbing the paint into the rock chip, use the side of your thumb to lightly wipe over the chipped area and thus level the surface by smearing any excess paint onto the paint surrounding the rock chip.
Step 3 - Use the SealAct blending solution with the included flat surface microfiber towel to wipe off the excess touch-up paint.
Lots of pictures in the actual article...
