That is at least something. Unfortunately I am pretty sure it wouldn't fly if brought to the authorities in the EU. My recollection is that the wording refers to a 'user', there is nothing which forces that the user must have bought the product and nothing which forces that the user must be able to prove it.
Most companies get away with things because no one has taken them to task on them.
pip, i appreciate someone else who knows how to look at an msds and determine how a product would and would not work based on what chemicals are present in it.
i'm thinking about making a combination spray that will actually do a good job at removing leftovers on paint while still being paint safe. but the problem still comes that to keep from getting scratches, you mostly always need a surfactant, or you need a special wax/sealant that has cleaning properties so that it cleans its surface before it lays down, and what you have left over on top gets buffed away.
2-2. Chemical description Chemical formula Con
tent CAS No. Remark
Isopropyl Alcohol < 30% 67-63-0
Dionized water > 60% 7732-18-5
Sodium lauryl ether sulfate 1%-3% 685-34-2
odor additive 1% proprietary
carpro eraser ^
contains water and ipa... along with SLES
Sodium laureth sulfate, or sodium lauryl ether sulfate, is an anionic detergent and surfactant found in many personal care products. SLES is an inexpensive and very effective foaming agent
you can't honestly tell me that you are putting a product on that removes oils, then leaves a film as well then say that it really did it's job can you? i'd believe that yes, it does remove oil buildup , but removing a polymer sealant or wax? doubtful based on ingrediants.
if it contained xylene/naptha instead of ipa, i'd be more apt to believing it.
carpro is more of less a glorified ipa, with stuff you do not want in an ipa cleaner.... scents and surfactants
panel wipe from gtechniq probably appeared more useful because it actually was. it is formulated like a lot of bodyshop wax and grease removers that have been in use for a long time. containing petrolium distillates.
ethanol, propon-2-ol , toulene (much like xylene).
i would say panel wipe is more apt to removing a lot of different things that the eraser just wouldn't touch (eraser is more likely to cover up i would say, than remove).
as far as panel wipe is concerned, you would have to really do some testing on different types of polymer sealants based on the type of polymer used, to see whether or not the combination of ingredients is right to dissolve the polymer you used. polymers are basically plastic from what i know, and ipa is not going to dissolve any plastic that i know of.
so far the only thing that looks like it will definitely remove a polymer sealant will be polishing, and then removing those polishing oils with anything you have with a 10-15% ipa mix, or something similar to a bodyshop safe solvent for paint cleaning, like panelwipe or common paint prep/paint cleaning chemicals
