Calendyr
- Jun 9, 2013
- 3,996
- Thread starter
- #21
All the brake kleens and spray degreasers are petroleum based. I find they come out with a little too much force and splatter. Spraying it in a cup and brushing it on works but it evaporates quickly and you lose product. I've used solvents from a solvent tank when I worked as a mechanic and they have non-flammable solvents these days. When I used them it was kerosene which is a form of diesel fuel. I have a gas can dedicated to diesel fuel and when I run into a tough engine detail I pour an inch of diesel fuel into a coffee can and use my old detail brushes to dab around the caked on oil and grease. It melts right off. Diesel doesn't put off a lot of fumes because it's heavier than gas but it's still a flammable substance. I keep cardboard under the engine when I clean engines and use it to start fires in my outdoor fire pit. I'm not recommending this procedure to anyone but just laying it out there for those that have familiarity with diesel fuel because it's a bargain product that works very well. I don't want to see anyone get burned or injured. I find it safer than carb cleaner, starting fluids, and brake cleaners. Just sharing.
Ah! Thanks for sharing... I would never have guessed Diesel fuel was a good degreaser... I was more Under the impression Diesel was closer to oïl than gasoline... Will have to get some and try it if I run into a caked on grease again.
