I want to make a logical choice in terms of rinse. I have an older RODI unit. I want to have it fed into a water tank and use that for the final rinse step.
1) Should I run an entirely different pump for this?
2) If not, is there a safe way to tie it into my existing CoxReel pressure washer hose?
3) Tank/reservoir size, I assume ~20 gal? 2gal/minute I assume that gives me enough to do a thorough wash on 1 car, or run 2 cars if needed since to refill it will have to run for many hours.
Since I have my pressure washer on the wall, I cant really gravity feed it down. I dont want to mount a tank on the wall.
Since locally tap water TDS is ~800, its just plain stupid to try and use a DI filter only. I can fill the tank for cents per rinse instead.
Suggestions?
Thanks
Suggestions?
Thanks
