Detail from Saturday (07) Lexis RX 330 Suv
carguy
The second detail for same customer as the mini cooper.
Process: Interior : vac, window with perfect glass,matts cleaned with citius
degreaser. vac with wet vac.
Leather treated with meguires conditioner with aloe
#### pit polished with klasse aio and plastic trim
Seals treated with black again.
Exterior: Pressure wash rims tires wheels wells with Zep
citius degreaser.
Pressure wash engine compartment degrease with
Zep citius degreaser and rinsed off,dry with towel
Pressure wash exterior with foam attachment and
NXT soap cut with dawn, used grout sponge to
wash, let sit 3 minutes then wash,rinse,clay with
DP clay and soap and grout sponge,rinse off then
Guzzler to dry and micro towel.
Meguires 2.0 paste wax applied with foam pad by
hand.
Dressed all exterior with black again, wheels, tire
wells aa foam was used.
Rims used klasse aio.
Wax sat for 25 minutes removed after exterior trim
was dressed.
Windows klasse aio.
Tires dressed with meguires season all dressing.
All comments welcomed, meguires 2.0 is a nice paste wax to use on all colors.
nice work, love the color reflecting in the sunlight.
Awesome job,
What did you use on the carpets to get them so white again?.
Also, how do you like that Megs NXT 2.0, have you used other sealants to compare it to? How would you rate the reflection/durability from 1-10
Thanks!
Awesome job,
Thanks!
I uses zeps cituis degreaser spray on sit few minutes, spray water agitate with brush,vac with wet vac.
Really like the meg 2.0, I usually let sit, I dressed all exterior trim, remove with micro towel by hand.
The only other sealants I use is Klasse aio, DP sealant, they both have great reflection, only if prep the paint is correct, clay, 50/50 alchole wipe down make sure to the touch squeek of the paint is smooth, very thin coat by da and grey pad # 3-4 speed, mist with cold water, wipe with micro towel, customers are amazed at what I do, I then say that is why you are paying me to do it.Im the MAN
The reflection rate at 9.0 Meguires, that is if everything as I said above is done. That goes for Klasse aio, DP sealant also, rating on these two 8.5 to 9.0.:righton:
This is what works for me. www.unlimitedautodetail.net
