Detailer's 8 Gallon 2.5 HP Wet/Dry Auto Detailing Vacuum
the lift number is what you look for in vacuum. not horsepower.
And this vacuum rivals the lift of the metro shop vac which is pretty much the standard for powerful vacuum's for detailing. 90" of lift is serious power.
btw, I want this vacuum pretty badly ! :)
I wish i realized this before I made my purchase. A few months ago I bought a 6.5hp shop-vac. It only has 80" of lift compared to this... live and learn! I realized my mistake after a different member posted their review of a different vacuum and the mistake I made, I could care less about hp rating. I want a vacuum that sucks! I mean is good, I mean sucks.... well, you know what I mean! :)
Sent from my DROID BIONIC using Tapatalk 2
2.5hp?? Seems low for the price of the vacuum. I bought a brand new RIGID 5hp compact wet/dry vac for under $100.
I think so too 2.5 for $225.00 ? If Autogeek teamed up with the folks at Shop Vac,at least should be the same price no ?
If you do a quick search online you will find the same brand vacuum (Shop-Vac) with more power 6.5HP instead of 2.5HP and with 16 gallons instead of 8 gallons for $74.00 less,and with that much left you could get even more detail stuff.Don't understand why some stuff here is so overpriced.
The thing though is AG's is actually more powerful, it has more water lift. 90 vs 60. A quick look at shop vacs site, I do not see a similar model to this AG unit. The closest I see is an industrial vac that has 2.5hp and the same lift. Only thing is it is huge at 22gal. This little vacuum is a heck of a little machine. Im becoming more and more envious and would trade mine in a heartbeat for one.
Great review by the TS. But you can't argue with this. It's the exact same reason I ordered a similar model from amazon earlier this week for $123 with all attachments and a detachable blower.
http://www.amazon.com/Shop-Vac-9633...WU2U/ref=sr_1_2?ie=UTF8&qid=1338680317&sr=8-2
2.5 is more powerful than a 6.5 ? You said it has more water lift,but whomever buys this vacuum isn't buying for the "wet" capabilities,just for the dirt in the carpet or maybe to blow dry the car.I just think with the money difference you could get a bunch of other detail stuff.
So you think cause a vac has a motor somehow rated at 6.5hp but only has 60" of lift has more suction that a vac reasonably rated at 2.5hp and has 90" of lift. The 6.5 is rated @ 160 CFM and the 2.5 is rated at 185CFM. Try going and buy a real electric motor rated at 6.5 hp and plug it into a 15amp household circuit ...pop goes the circuit breaker. No way! This 2.5 will out perform all those cheap 5 and 6 hp units at lowes and HD. Look at the performance ratings not the great big 6.5 HP on the box!
Thanks for the Great Review BobbyG:dblthumb2:
There are quite a few more things to consider when purchasing a vacuum than sheer "horsepower."
What you really need to look at is the air flow (CFM) along with the sealed pressure (lift). A 6.5 "horsepower" vacuum with a CFM of 85 and a sealed pressure of 65 is not as powerful as a 2.5 horsepower vacuum with a CFM of 185 and a sealed pressure of 90.
The Detailer's Shop Vac also includes a host of accessories that are sold separately with lesser vacuums, including the Ultra Web cartridge, 2 ply collection bags, etc. Your standard $100 shop vac will have a power cord that's 10-15 feet long, tops, the Detailer's Shop Vac has a 35 foot power cord. Plus, the 12 ft hose included with the vacuum locks on and is crush resistant.
And probably the most overlooked feature on a vacuum in this price range is the 2-stage motor. A 2-stage motor provides a longer operating life and quieter operation.
All of these features add up to a really nice piece of equipment. :dblthumb2:
Thanks for posting such a thorough review BobbyG, I learned something today that had evaded me previously.
Bobby,
I bought this vacuum after reading your review and a seeing your pictures. I already wanted the vacuum but your writeup pushed me over the edge.
I have a question. Which filter/bag should I be using ? I am only doing dry work inside the car. basically vacuuming up typical particles from daily driving. sand, dust and small particles.
Should I be using the yellow bag filter for this ? or the blue wet/dry filter that is already installed on thtie vacuum ? Is there any benefit to using one over the other ? Also, is it necessary to remove the blue wet/dry filter when using the bag ?
Bobby,
If dry work is all that this vacuum will be used for then I recommend the yellow disposal bags. Yes, the blue wet / dry filter should be removed prior to installing the yellow bag.
As a side note: I used my vacuum yesterday and what a pleasure it is to use....
Great review BobbyG! Looks like a really nice unit.
I have 6.75 hp, 20-22 gallon Craftsmen. It's about 10-14 years old. One thing I like about my unit is the motor is detachable and can be used as a leaf blower. It works great blowing out the garage and blowing off the car, however, you have to be careful doing the latter.
One comment on suction power, regardless of all the numbers others have mentioned here. Nintey (90) to one hundred (100) inches of suction is a tremendous amount of lift for a vacuum, but each lift rating, per vacuum brand, is only comparable if the hoses are the same diameter.
Ninety inches of lift in a 1.5" hose takes a lesser amount of horsepower than 90 inches of lift an a 2", 2.5", 3", etc. This is where the horsepower factor will make a difference. In other words, it takes more horsepower to make 90" inches of lift in a 2.5"-3" hose than it does an 1.5" hose. The cfm's will also be greatly reduced or increased depending on the hose size. Of course, most of you realize this.
(NOTE: The above statement has nothing to do with how manufacturers rate their vacuums, or reach the horsepower ratings they advertise. In the above statement I'm speaking specifically from a numbers point of view. Larger hoses take more horsepower to create a given amount of lift.)
That said, I prefer larger hosed vacuums for most of my work because of not having to unclog a hose. Years ago most shop vacs had these small hoses and were a pain in the backside. Of course, vacuuming most dirt and grit in cars the small hoses are fine. It's the occasional big chunk of whatever in a car that's the culprit and I don't have time to fiddle with unclogging a hose or hooking up the larger sweeper.
If your car never sees large pieces of debree (read, rarely gets real dirty) then the unit reviewed would be an awesome option for you.
EDIT:
These comments were not meant to detract from BobbyG's wonderful review, rather, to cause folks to consider what sweeper will best suit all of their needs.
Hey Bill,
I enjoy reading others opinions and comments and yours are spot on! :props:
The larger the hose the more power required to lift the larger volume of water. Many shop vacs came with the 2 1/2" diameter hoses but the ones I see today seemed to have scaled back to the 1 1/2" diameter.
Like you I think the bigger diameter brings a bit more to the game....:dblthumb2:
Thanks BobbyG!
There are certainly lots of things to consider when purchasing a unit.
What I like most about the unit reviewed is the power the unit has for its size.
The Detailer's 8 Gallon 2.5 HP Wet/Dry Auto Detailing Vacuum certainly takes up less room in the garage, is lighter, and therefore easier to manuever around. My large unit is somewhat cumbersome which, at times, is a downside to using it. Also, if the car doesn't have large debree the smaller hose is much more easy to work with, especially under and around the seats.
I wouldn't mind owning the Detailer's 8 Gallon 2.5 HP Wet/Dry Auto Detailing Vacuum simply because there are times I don't need to drag the big sweeper out. I certainly wouldn't have to sacrifice any power, for sure.
Hose (length and how it attaches) and cord length are other great features for the Detailer's 8 Gallon 2.5 HP Wet/Dry Auto Detailing Vacuum, better than most units offered elsewhere.
