Detailing a jet ski
krouchchocolate
Has anyone ever detailed a jet ski before?
Also I just recently purchased a used jet ski, but the front of the jet ski is partially faded from staying out in the sun for too long. Is there anything I can do to restore the "gloss" back into it?
The black part right under the yellow part is where it is dull. Next to the TX numbers.
I have 2 jet skis that sit out on my dock 24/7. You can polish painted parts just like you would you car to bring back the gloss. On plastic 303 work pretty good buy nothing seems to hold up to saltwater very good.
Gary is right with salt water doesnt really matter what you do, salt water always wins. Not sure if you are using it in fresh or salt but either way there are things you can do to protect it. 303 is one of the best for the UV protection, but there is a lot you can do to restore the faded areas. Just needs a good polishing, and there are several sealants that do hold up better in the water, I like the Collinite Double Coat and or the Klasse twins.
http://www.autogeekonline.net/forum/show-n-shine/15353-2001-wave-runner-fuzion-style.html
So the black area just needs a good polishing. What kind of polish do you guys recommend? Right now i currently have the 3 stages of the optimum polishes. The polish, compound, and heavy compound.
I also have the klasse twins, so I will use those for protecting it.
The 303 you guys are talking about is the 303 aerospace protectant correct?
Optimum makes some find polishes. Just like with your car's paint start out with the least aggressive polish you think will do the job on a test spot and see how it goes. 303 Aerospace Protectant is correct.
On oxidized gel coats like on your pwc I would start with a compound first. Gel coats are different from automotive paint in which they are much harder.
I usually start with a compound and foam. If it doesnt work I'll switch to a wool pad. My last resorts for or very stuborn oxidation is 1500 wet sand, wool and 3m superduty.
For trim on anything that touches water i like SC1 ClearCoat. Its a great protectant thats water resistant lasts fairly long and best of all it smells like pixie sticks.
Is there a way I can tell if the clear coat is gone? Could that be why the paint looks dull in that area?
if the clear coat is gone, when you polish your pad will start to show the color of the paint. When you polish you are removing a small amount of paint. If you are polishing clear coat; the paint is clear (obveosly) so you don't see the paint building up on the pad. If it was the base coat (color) that you are polishing, you will be able to see the paint; that you removed; on the pad.
I just recently did a detail on my dads Seadoo PWC, and it's not nearly as fun as I expected. There are so many different panels that need to be worked on, instead of a few big panels. And so many different materials used on the body (there was like 4 different textures of plastic trim).
I used Optimum Poli-seal on the lower half. WG Finishing Glaze on the upper painted panels, with a coat of Collinite 845, topped with DP Max Wax (the DP was just for looks while it's in storage). All of the plastic trim was dressed with Optimum Opti-bond tire gel. The Opti-bond worked fantastic! It even looked good on the ruberized foam material on the back platform.
Here's a picture of how it turned out:
Jet ski's and boats dont have clearcoats. They have gel coats which is basically pigmented epoxy resin. The paint looks dull because of the fact that the gel coating has oxidized similar to how single stage paints oxidizes.
Is that on top of the color? Or is it a single stage type of paint? When I polished our Seadoo, there was no color transfer on to my pad... I guess it could just be because I was using a finishing polish.
On my jet skis the haul is gel coated fiberglass but there are a lot of parts that are single stage painted plastic. It would take much to go through the single stage paint with an aggresive compound so one needs to be careful.
No it is not on top of the color it is similar to how SS paint is with the color and gelcoating mixed together.
Yup your right. Only the haul is gelcoated and there is no particular reason to be careful except around trim since the coating is fairly thick.
Is this the collinite you are talking about Meghan?
18 oz. Collinite Super DoubleCoat Auto Wax #476, carnauba wax
I would attack it like polishing any other boat. Use a rotary, compound, polish, seal it.
The salt water can do so pretty bad damage to your PWC or boats. After you remove all of the oxidation, take it out of the water and wax it regularly.
Are you working by hand or by machine and if machine, which type?
Always match the product to the surface being treated, so
  • Treat paint like paint
  • Treat gel-coat like gel-coat
The exception would be it's usually okay to use Automotive products on Marine craft but you don't want to use any kind of Marine compounds on Automotive paints as they tend to be a lot more aggressive, this is why it's safest to use Marine product for Marine craft and Automotive products on Automotive paints.
It's both the hardness and thickness factors characteristic to gel-coats that come into play as pointed out and the thinness factor when it comes to automotive paints.
I will be working it with the Porter cable 7424(not sure if this was the model) with the edge 2000 pad kit.
Which marine products would you recommend to polish the oxidized area?
On my 1976 Starline Deville, everything I tested worked great although some of it was for automotive use.
1967 Starline Deville - Extreme Makeover
The 3M Marine Line worked well and it's a dedicated line for Marine Products. From page 2 of the above thread.
Mike Phillips said:
Someone asked me about the 3M Marine Line so I've taped off a section on the back of the boat to demonstrate the 3M Marine Rubbing Compound with a 8" Wool Cutting pad on the Flex Lightweight Rotary Buffer.
Note that I've removed anything off the rear deck that can be removed without too much work to enable me to do the best job of restoring this 42 year old gel-coat. Plus then I can clean up the holes a little and the thread for all the stainless steel screws and re-assemble everything nice and clean.
Here's the results from the compounding step.
I spent a lot of time compounding each square inch, I applied and removed 3 applications of compound with the wool pad. After that I used a yellow foam cutting pad and it seem to dull down the finish, so I re-buffed the entire area again with the wool cutting pad.
Here's the results, the gel-coat is very glossy but if you look at the second picture, it's also very hazy and this haze is the swirls left by the abrasives in the compound and probably also the fibers of the wool pad. You can see that after polishing the DOI is going to increase.
DOI = Distinction of Image. That is how clearly you can see the details of a reflected image.
In keeping within a system approach I'm going to use the 3M recommended Marine Finess-it II Glaze with a 3M Polishing pad.
Started with a 3M foam polishing pad (Per Manufactures instructions)
While it was working okay the 8" size pads are just too big for the shape and design of the back upper surface of this boat. So I switched over to the 5.5 Hydro-Tech Tangerine Foam Polishing and kid you not, this is a smooth polishing combo that quickly removed all the haze and brought the gel-coat up to a very high gloss.
Next I applied the 3M Marine Liquid Wax and because I prefer to apply all my LSP's by machine I used the Griot's Garage ROP on the 3.0 speed setting with a Meguiar's W-8006 foam polishing pad.
After applying the wax I came back to my office, uploaded the photos and posted this update. I'm going to go back out to the AG Garage and start cleaning up, I'll take a picture to show you just how much of a mess buffing out just one corner of this boat made and here at work we try to leave the garage cleaner than when we found it. (It's always clean so that's not saying much).
Maybe read through the entire Starline Deville thread, you might pick up a few pointers...
Also, Meguiar's makes an Oxidation Removal Kit and dedicated products, let me know which line you want to use and I'd be happy to make a recommendation.
:buffing:
Mike,
Thanks for all your help man! Are the meguiar's or the 3m the type of marine products I can find locally at my auto parts store, or would you have to order them online?
