:iagree:it also depends what your market will pay and the quality of your work.
well i really dont wanna mess with paint correction because i cant tell if the clear coat is thick enough to do any paint correction.what is ocw optimum car wax??so when u say duragloss im assumeing u mean TPP 105??kaio is a good cleaner. it isn't going to do any real correction. poliseal has very light abrasives and good cleaning abilities. both are good. poliseal is easier to remove. if you remove it with ocw it is fast and easy and gives decent durability too.
i would look at duragloss for cost effective, easy to use and durability as well.
pick a good wax for your customers that want looks over durability and you should be covered.
ok so ocw is for customers that want more of a gloss finish & dg105 is for protection longevity?would KAIO still be a good cleaner/polish to use?i just want to do a 2 step after the vehicle has been washed and clayed.pc and light polishes aren't going to do much damage but i find the majority of owners want clean interiors more than paint correction.
you can add that later when you have more experience.
ocw is optimum car wax. dg 105 is the sealant i would recommend.
what interior products and tools do you have?
lol thanks.but im always open for suggestions because im new to this stuff.ok so what i should have is kaio w/ ocw if they want a glossy finish or kaio w/ dg 105 if they want longer protection?kaio is fine to use before you sealant or wax. even after clay a good paint cleaner will remove stuff from paint.
sounds like you are ready to tackle the jobs. good luck
