More....
For dressing and protecting, here's the lazy man's method. I'm not a fan of this method but it is quick and easy. Also comparably cheap.
From the second post in this thread...
Review: BLACKFIRE Trim & Tire Protectant Aerosol
Exterior Trim
Some exterior trim is easy to dress because it's easy to get to and somehow wipe a trim dressing on with some type of simple applicator pad.
BUT sometimes some exterior trim is a real pain in the rear to dress due to the complicated and/or intricate design. Such is the case with a lot of car grills. They usually have some form of rectangular or honeycomb design that you can't easily get an hand applicator into thus you can't dress the trim by hand. That's where an aerosol version of a trim dressing comes in handy.
Here's a great example of trim that's hard to dress the traditional methods of hand-wiping...
BEFORE
Here's how the plastic grill looks after washing the car. It's dull and lifeless. With time, if nothing is done it will oxidize and turn white. Once an intricate design grill like this turns white with oxidization it's pretty much game-over. So my best tip is to start treating your plastic grill trim as soon as you buy your car. If you always "do something" to it.... it will always look new. It's when you neglected exterior plastic trim over time that it goes down hill.
Now this is easy-peasy....
Just spray the BLACKFIRE Trim and Tire Protectant into the grill and do it from a couple of different angles to fully coat all of the plastic.
Here's a half-n-half shot...
The left side has been treated and the right side is how it started out....
Here I've sprayed a little further....
Pretty easy to see the dull plastic portions of the grill that I have not applied the protectant.
Finishing the job....
Technique Tip
Use compressed air to blow the dressing completely throughout the grill area. For this I like to use the Metro-Vac Sidekick.
Technique Tip
To REALLY push the BLACKFIRE Trim & Tire Protectant into all the nooks and crannies of a grill I like to use a RaggTopp Haartz Convertible Top Brush.
After treating the grill use a clean, dry microfiber towel to wipe off any excess from surrounding paint.
BLACKFIRE Trim & Tire Protectant is the fastest, easiest way to treat and protect plastic grills or any intricate, hard to detail plastic surfaces.
Review
Without investing a ton of time to use a non-aerosol product, I can't think of a faster or easier way to make a plastic grill look sharp and new. If your car's plastic grill looks dull and ugly then get a can of BLACKFIRE Trim & Tire Protectant and restore the new-car look in minutes.
