Klasse Act
- Feb 21, 2012
- 27,842
- 2,959
Autobiography...![]()
Great job Deyon, I would've used everything in the arsenal as well, NO STONE UNTURNED and afterwards you have NO regrets and feel satisfied
Love how your winters look down there
Nice job, looks great in the pics.
What I learnt from my previous place of employment is that it's badge snobbery, they don't care about reliability, they're paying for the badge, and they accept that stuff is just going to go wrong with them.
Thankyou.
Was a nice day for it, even if I didn't see much of it with head down working. It's not always blue sky's in winter for though. Yesterday was pretty ordinary, very grey with a chilly breeze. Nothing like you get of course.
Two things come to mind -
- First, a blocked exhaust port or spark arrestor in the muffler. This is mostly applicable to 2-stroke engines, but it you don't run the machine at full or high revs often, the carbon doesn't burn off properly and eventually causes it to build up and block, ultimately preventing the engine from exhaling.
I haven't pulled down a small GX25 / GX35 Honda before, but you would need to inspect the small muffler outlet screen, which your unit may or may not have as there are a few different designs for these engines. Remove any built-up carbon with a wire brush or by heating it with a flame and again agitating with a brush.
For the exhaust port, you will need to remove the muffler and inspect the port for carbon build up. Remove by gently scraping the carbon away. In both cases, you will need to remove the engine shrouding. While the muffler is removed, make sure the inlet is not blocked either.
- Secondly, it could be that engine is not getting enough fuel at full throttle. In which case, check the fuel filter in the tank. Otherwise, you will likely need to rebuild or replace the carb. These are a diaphragm carb, which become hard with age and don't pump fuel properly. Usually, you will have starting issues as well. On my GX25 powered Atom Edger, I had the carb rebuilt and fuel line replaced to solve this issue.
Yeah you can surely see it! I don't have Brembos but because my car is "track ready" it comes with pads that really dust upDo you have the stock Brembo pads? They are dust generators. They also destroy rotors. I've switched to Power Stop years ago because of that.
My first new car was a Contour SVT, the "US Mondeo". This was the day I sold it in early spring of 2005. Sadly, this is the only pic I have of it as the old picture hosting site I had back in the day went under and I lost all the pics...everything![]()
Speaking of that Mondeo, I feel like providing the story on that car. ...
