DFB
- Aug 12, 2019
- 4,895
- 2,970
- Thread starter
- #1,521
Having ran the updated wide-mouth MTM foam cannon for a few months now, I've been very happy with the improved usability brought on by the wide mouth bottler. But there is one problem I have encountered, something I actually discovered very quickly.
I use a foam cannon for wheel cleaning. I'm also seated when, with the stool and bucket on wheels so I can shuffle from wheel to wheel without getting up. With a bucket full of water and tools, there was nowhere to put the foam cannon when not in use. The solution was a bracket to hang the foam cannon off the side of the bucket, something that took me ages to find at a reasonable cost, I even contemplated having someone make me one.
You can imagine my disappointment when I discovered the updated MTM bottle and cap arrangement was not compatible with either the Maxshine or MTM bracket. I can't see how an updated version of either bracket would work considering the lack of clearance between the foam cannon body and the black adaptor cap. So, I've been back to fumbling from wheel to wheel managing the stool, the pressure washer gun/hose, bucket and foam cannon.
Recently, I came across these quick connect wall brackets. As usual, where were these when I was looking for them a year ago, perhaps I'm just ahead of the curve?
Amazon.com
Anyway, these are actually very cost effective and function differently to other quick connects. Rather than lowering the collar to insert or release a fitting, these are spring loaded, so you simply push the fitting in to have it lock in place, then pull back to release.
The plan was to mount the bracket to my detailing stool, which will have the foam cannon resting between my legs for quick and easy retravel. After checking clearance to the floor, I secured the mount with screws.
Problem solved! :dblthumb2:
Amazon.com
