Two Ranger's washed today in record time. Time constraints meant I had to hustle today. Although I did get to try some new products.
Not a new product, but rather a different use. McKee's N-917 is such a versatile product from rinse-less and waterless washing to clay lubricant, quick detailer, interior cleaner/detailer and even a water softener or paint prep. Another less obvious use is as a windscreen washer fluid.
The surfactant base of N-914 makes this possible. For this role, I dilute the product at 128:1 in normal tap water. Because of the water softening ability, this eliminates the need for demineralized water. I then fill the bottle to the brim and job done.
Again, not a new to me product, but I have been loving this TRC Ultra Utility Brush for applying dressing to larger tyres. It's just so ergonomic to use for this task, and less messy, to the point I don't bother wearing gloves. In this case, I'm using Carpro Perl at 1:1.
On to a brand-new product, Bowden's Dry Spell rinse-less wash.
This is the brands first attempt at a rinse-less wash, one that I think will be a hard sell in Australia. The desire for rinse-less washing just isn't as high, or even understood in Australia compared to the USA or Canada. Which is kinda weird for such a dry country. Apart from pre-mixed waterless sprays, I can't think of any other rinse-less wash concentrates available in a big-box store. So, Dry Spell might be viable if Bowden's can convince consumers of it's benefits.
First of all, Dry Spell is surfactant based, putting it alongside N-914 and differentiates it from the polymer based ONR or Absolute. The scent is not unlike apple juice and the lurid pink colouring is extremely vivid. I initially thought the colouring was excessive, but when mixed into the bucket, it makes it completely obvious something is actually in the water. This is in contrast to Absolute and even N-914.
Like any rinse-less, you first mix up the solution in a bucket. For Dry Spell, 40ml of concentrate is added to 8 liters of water (200:1). Agitate with your hand to mix.
You then make up a pre-spray solution at 40:1, 15ml of concentrate in 500ml of water. Bowden's recommend using distilled water, but I have good low TDS water so did not bother.
In this case, I pre-soaked the whole cab in one hit and followed up with the UBS. Bowden's method recommends the microfiber towels, but either way is fine.
I then dried the car, using a little Koch Chemie Quick Shine.
Overall, I really enjoyed using Dry Spell. Like N-914, the surfactant base makes it a touch sticky, but it dries off to a streak free finish. It doesn't reach the same slickness levels of Absolute, but for their first try, Dry Spell is impressive.
To cap off my afternoon, I spent 45 minutes on the phone with my favorite supplier, talking new products and industry gossip........................and discussing something I'm working on for the garage. :xyxthumbs:
