DFB's Garage
In the past few weeks, I've been fueling my OCD tendencies with other interests......................and enjoying every single second of it. In addition to the actual subject matter, I'm trying to push myself to make more videos. Quite often, the process of getting the camera out makes to film a particular subject has me over thinking what I'm trying to do. When in reality, its just a matter of turning the camera on and going with it. But, I'm pushing through, mainly so I become more confident with the camera rolling nest to me, but also with editing.
But, I'm happy with how I'm progressing. I just need to cross the barrier of being seen and heard. As a shy person, that may never happen. With my lates videos, I'm very pleased with how they turned out. Although, I'm not sure the neighbours agree with that. :unsure:
With that said, I thought it was about time for more detailing content. Today, it was the Mustang's turn.
To start, the wheels were pre-treaded with NV Purge while I filled the buckets. With the Purge rinsed off, I went back in with Brake Buster for the tyres and foamed Carpro Reset for the wheels. From here, I applied some Hydr02 to top up the coating, then Atom Mac on the rotors.
For the wash, once again the transcendent Reset, teamed with the Carpro DabDab.
Following the final rinse, I again grabbed Hydr02 and applied it to the upper and lower grills as these weren't ceramic coated. From there, Amplify was the drying aid, Opti-Coat Clean & Protect for the glass, OG TD on the tyres. Moving to the interior, I gave it a wipe down with Griots Interior Cleaner, then applied a fresh layer of ColourLock Leather Shield to the seats, steering wheel, gear selector, handbrake and door panels.
Freshly cleaned and ready to swap places with old blue..................
Some bike detailing today.
This bike has been in storage for a while, so it was extremely dusty and had a fair bit of oil and grease build up on the crank, gear cassette, derailleur and chain. So, I started by spraying those areas with Bilt Hamber Sufex HD mixed at 1:1, which is quite a strong rate. I then foamed with Touch-less.
Touch-less doing its thing, breaking down contamination, then pulling it from the surface and onto the ground.
After a rinse, I followed with Hydr02 and dried it off with the EGO. As a finishing touch, a little Bead Maker on a towel.
Then, I replaced the lubrication the wash removed, this time trying something new to me, WD-40 Gel Lube (Spray & Stay No Drip) -
Spray Gel Lubricant for Tools | WD-40 Spray Gel Lube | WD-40
Gel Lubricant - WD-40 Australia
Effectively, a touch free wash that delivered the result I was looking for.
How many Km on that rig?
Quite a lot actually. Can't remember how long I've had it, probably 15 years.
I used to ride quite a lot, for both exercise and purpose. You can see the bike lock under the seat, I'd often ride down town instead of driving.
It must be the detailer in me, but the following is hard for me to grapple. A beautifully clean, virgin chainsaw only stays that way for so long. But.................. they were made to work and made to get dirty, so it was time for the 500i to make its first cuts.
I'm using pine here, at some stage I want to put it into some hard redgum or box, really make it work! Once upon a time, you'd drive into the bush and take your pick. But with everyone having a camera on them these days, I don't fancy being caught breaking the law for the sake of a video or my gratification. In any case, it's probably good for such a fresh saw to have a few easy cuts on its belt before being made to work long and hard against Aussie hardwood.
There is NOTHING like the sound of an angry chainsaw!
Important to note that the saw was warmed up prior to starting these cuts. I'm also more confident in drop starting it, you just have to man up! 💪
And doesn't she have a lovely voice? Keep following for more on that!
The Wildtrak was in the box seat this morning. It's been cold, wet and miserable of late, so I had some work ahead of me, inside and out.
Starting out, I foamed everything bar the horizontal panels with Bilt Hamber Touch-less, wheels and wheel arches included. With the roof and hood not covered in road film, I see no reason to douse those areas with an aggressive pre-cleaner if it's not needed. Normally, I would foam the pre-cleaner after doing the wheels, but with the cold conditions, I didn't have to worry about water drying on the paint while attending to the wheels.
Using Touch-less on the wheels and wheel arches is such a genius move as it significantly reduces the amount of grime you have to plough through with your brushes, which is always higher in wet winter conditions. With that all rinsed away, I went in with foamed Brake Buster, then foamed and contact washed the rest of the vehicle with Carpro Reset.
For today, I decided to give Hydr02 Foam another shot. Mixed at the recommended 9:1 dilution, this soap doesn't produce shaving cream foam. In which case, why call it Hydr02 "Foam"? In this instance, I just foamed it on, left it for 60 seconds and rinsed it off, no contact with a wash mitt. I think using it this way is probably better than trying to actually clean with it. Overall, I was very impressed with the uptick in slickness to the paint and the boost in hydrophobics. I'm trying to keep the CanCoat EVO alive for as long as possible.
After a blow down, which I'm finding the EGO batteries really dislike the cold conditions, I went in with Megs HCD. Considering I used Hydr02 Foam, this was probably overboard, but again, I'm doing my best to keep the coating at peak performance.
From there, exterior glass was attended to using the excellent Stoners Ceramic Glass Cleaner, switching to the regular Stoners for the interior glass and info screens. ADS Pilot for the interior cleaning, P&S Swift was used to dress the rubber mats after also being cleaned with Touch-less. The final steps being a light wipe down of the wheels using Bead Maker, and the tyres dressed with Carpro Perl.
It's easy to become desensitized to paint slickness when you are always spraying on something to make gains in that department. But after using Hydr02 Foam and Megs HCD, I have to say the slickness was extremely high. So perhaps I'll start using the Hydr02 Foam more now?
