Did Dodge/Chrysler Change their CLEAR Coat?
Ive been doing a few LX cars lately (mostly chargers and challengers) and have heard that the 2012 line of Chargers/Challengers no longer offer the Toxic Orange color because the plant in Japan was damaged in the earthquake.
I did a black 2012 Charger...only 10 days off the rail a week or so ago and i went to use the Megs MF D300 and pad on it...which usually gives a very nice finish, but after wiping it clean the paint was seriously hazed...had to go to 205 on a foam pad to clear it up.
So my question is...did dodge (chrysler) change their CLEAR also? I did a Black Challenger as new as a 2010..and D300 finished off beautifully...so i cant figure why the same pad/product combo on the same make of car (Chrysler), would suddenly haze up.
Thoughts?
My only thought is the only paint issues I have heard of from the earthquake/tsunami were regarding pigments...so that would rule out any clearcoat issues.
Thats what i thought but i cant figure out why the factory clear would haze all the sudden with D300 which is suppose to work with factory clear
I know that on later model lexi there have been some chipping problems b/c the paint formulations are slowly being changed to be more environmentally friendly.
Perhaps those changes are being adopted by more companies?
Yeah, that doesn't mean they didn't change their clear, I just don't think it had anything to do with the tsunami.
Chrysler does have a new owner, certainly conceivable they changed their paint for any number of reasons.
Couple of things I consider:
-Most OEM automotive manufacturers have at least three paint suppliers.
-These paint suppliers must the OEM's manufacturer's engineering and quality-assurance standards.
-These standards may include a tolerance of +/- 5%; must be within a given price-point (per: the bean-counters); the selected color-wheel-matchablity; but, since it's the CC you're asking about: the "hardness", scratch-resistance, CC paint film thickness, etc.
-The OEM's are continually wanting to cut the costs of BC/CC paint systems...And are beseeching the paint suppliers to assist them in that venture each and every model year. (If they don't comply...they're usually dropped as a supplier)
-Some of those BC/CC paint suppliers being asked for cost reduction and "better" paint systems include DuPont and PPG (It's been estimated that DuPont and PPG manufacture more than 80% of all automotive paint used worldwide....Including the base-coat/clear-coat paints....and their paints are on at least 90% of vehicles leaving the assembly lines everyday).
-It's very difficult to find out on a day-to-day (often hour-by-hour) basis which of the paint manufacturer's paints (BC and CC) is actually being applied in the OEM's factories paint kitchens. And I don't believe they'll tell...proprietary issues, as usual.
-As long as the OEM's paint standards, including quality-assurance, are being met, then they spray away.
-Also: At the assembly plant, and the receiving dealership...There are times when a vehicle is pulled aside for "cosmetic repairs"....These type of re-sprays do not have the luxury of having the same paint kitchen's baked-on ability....the qualities (such as: hardness) of the CC may be compromised.
I see the above listings as some factors that play a role in determining any "changes" that do/will occur in BC/CC paint systems.
Perhaps these same factors are a force to contend with when someone does any paint corrections on a vehicle? The all important: TEST SPOT, therefore, looms quite heavily these days!
Hope this helps some.
All very interesting points. No big surprise they try to cut any corner they can. And trust me, i did a TEST SPOT before going over the whole car. Thats why i opted for 205 on a polishing pad since it was a single pass on a new car. Turned out nice...just wondered why D300 was acting up.
So there's a possibility--that the vehicle was damaged in-transit or on the lot and had a repainted panel--which is the one you chose for your test spot?
It's also important to consider, just to add to Bob's points above, that a change in any one component of any layer of the film build can have an affect on how the top coat cures and cross-links due to slight changes in solvent content and off-gassing -- even when it is a thermocured OEM finish.
