Difference ... Prewax cleaner/cleaner wax
Vizzin72
What is the difference between pre wax cleaner and cleaner?
Trying to decide what product and pad combo to use on a some what faded but in good condition in terms of scratches red paint.
A pre-wax cleaner is a paint cleaner, it's job is to clean the surface and prepare the paint for application of a wax or paint sealant. It offers no protection in and of itself. After using a pre-wax cleaner or a paint cleaner you would need to apply a wax.
A Cleaner/Wax or AIO is a product that cleans, polishes and protects in one step.
Two very different products.
:xyxthumbs:
Then what you really want is a Medium Cut to Light Cut Polish, a paint cleaner that is abrasive or a cleaner/wax that is a abrasive.
To remove swirls you need to remove a little paint.
See my article here,
The benefits of a light paint cleaner, cleansing lotion or pre-wax cleaner
And this one,
Words mean things... just ask any Lawyer...
Word Definitions - Compounds, Polishes, Glazes, Paint Cleaners and Waxes
LSP
Both of the above can be found in my article list.
I have white and green LC pads and meguires cleaner wax and UP
What is an example of prewax cleaner? Is it done before or after polishing?
Pinnacle Paint Works Cleanser is a solid one , Griots has one but the name escapes me. Tome a cleaner is done in lieu of polishing. Mid cycle details where you are just reapplying a sealant or wax is where you would use the cleaner. If you are polishing I feel there is no need for a cleaner as the polishing is actually removing a small amount of the finish and what's left should be pristine and clean. Hope that helps.
it helps ... i can try polishing a little bit on one section and applying cleaner wax on another section and see which one looks best ... i guess i hope that the cleaner wax will do becuase it will save me time in not having to buff the car out twice ... if it doesn't look right i will just have to polich it and then not use the cleaner wax altogether and just go to a normal wax.
