Dilution ratios for 32oz bottles
Dr Oldz
Active member
1:1 = 16oz
2:1 = 10.67oz
3:1 = 8oz
4:1 = 6.4oz
5:1 = 5.33oz
6:1 = 4.57oz
7:1 = 4oz
8:1 = 3.56oz
9:1 = 3.2oz
10:1 = 2.91oz
12:1 = 2.46oz
15:1 = 2oz
20:1 = 1.52oz
To add to the above!
Here is the amount of product to add to a 32oz bottle then fill with water for a TOTAL of 32oz!
EXAMPLE - To make a 32oz solution of APC at a 3:1 ratio add 8oz concentrated APC and fill with water!(You will be adding 24oz water TOTALING 32oz) Say for a 15:1 solution, you will add 2oz concentrated APC and fill with water(You will be adding 30oz of water TOTALING 32oz)
If you are using a 16oz bottle, cut the amount in half and fill container with water. So to make a 16oz solution of APC at 3:1 you will use 4oz of concentrated APC and fill with water(here you will be adding 12oz of water TOTALING 16oz)
Good for bottles that aren't label. I got mine at Autozone and they are only label up to 10:1 so I just have to estimate if I need something more diluted.
Now I don't havta get my calculator out every time.
Thanks muchly.
It's difficult to argue with facts.......:dblthumb2:
Thanks Doc! :props:
Thank you, Thank you !!! This is just what I have been trying to find out for the last week.
This and the original one by Mike P should be a sticky. Very helpful info.
Dave
Thanks Doc!
Great information, now get to work on 24 oz, 16 oz, 8 oz bottles :laughing:
Thanks Doc!
Just cut in half for 16oz bottles! :p
I would say 8oz and 24oz are pretty much uncommon for diluting chems!
I have a spreadsheet but here is a JPG of the table. If anyone wants a copy of the XLS file just send me a private message.
