I have a question about DI water. I read on some forums that softwater will work like DI water to reduce spotting, but this is a lie. I bought a 200 dollar portable water softener to be used with a pressure washer. Although it is nice and brought my 17 gpg\250ppm water down to 20 ish ppm, I still get spotting almost as badly as before. The softwater has done wonders to increase snowfoam volume thru my mtm foam cannon, so i think I will keep it. I plan on implementing a series of Y valves so that I can choose between:
1) Hard water
2) softwater
3)Softwater + DI water inline
So I went ahead and purchased a portable DI tank to be used inline with the water softener.
Who here has knowledge of these things? Does using a water softener extend the life of the expensive DI resin? I plan to use DI only as a last rinse because its so expensive. The one i bought claims to give 180 gallons at 250ppm. Which means if I use a 1.79 gpm spx3000 (some claim that in real world use, it only uses 1.1 gpm which is actually a good thing in this case) AND if I do my final rinse in under 3 minutes, then I would use a total of 5.37 gallons. Ofcourse I would lose some water thru the PW system and miscellaneous, so Ill probably use 6 gallons or so a wash. This means my DI should last me thru 180/6=30 washes.
Refill resin costs 90 bucks shipped for the unit so if i get 180 gallons of water, I am paying about 50 cents per gallon which is only twice the cost of drinking water where I live.
Please share your opinions, I am also new here but have been a long time lurker. Thanks!
1) Hard water
2) softwater
