DIY LED Work Light (much better than halogen!)
I've read two or three threads about work light stands similar to the one you've put together, and you've convinced me that it's worth the investment to get the LED lights.
I've been struggling with the lighting in my garage and have had to redo various things once I see the car in the sunlight. I bought an inexpensive halogen light from Harbor Freight, thinking that would help, but not only is it blinding and hot, it makes the paint look far worse than it actually appears when viewed outside in full sun.
Do you know if the stand that you're using is heavier than the one on Amazon? Just wondering how sturdy it is when raised up.
Absolutely awesome, GREAT post!!! I will be copying your idea and building a set for myself, thanks for sharing!!
__________________
LED bulbs are awesome! Just don't get too crazy with them.
I found the dual LED lights on my Nokia icon cell phone work the best of anything I've tried for close up paint inspection....and its free...so to speak as in not having to buy a new piece of hardware.
Nice write up! I made this set up a few weeks ago, but currently only have 1 PAR38 bulb.
Just for everyone: Make sure that the bulb you get is a SINGLE DIODE bulb. I could only find a PAR38 5000k single diode (the one that Zach linked) at Lowes (Utilitech). The ones at Home Depot are multi-diode.
And that is better because you have one big reflection to look in for swirls instead of multiple smaller ones? Or is there another reason?
I don't see anywhere that it tells you if the light is a single diode bulb.
This is excellent! The only problem is it's 110V not 220V so I just need equivalent bulbs.
I am still using halogen and object the heat, it's already very hot in here when I work outside, over 30 degree centigrade about 95F+ in midday, add the halogen heat, I am dehydrate fast.
A very slick and economical way to add lighting to your detail!
Thanks Zach! :props:
Are LED's living up to the durability claims? I have seen more early life failures with CFL's than incandescent.
Very cool! I've been wanting to DIY a set up like this. But I swear every time I'm in HD or Lowes the LED are always a few $ less then before!
I was wondering the same thing Al. With the extremely high initial cost and questionable durability I might forgo my build....I'll have to research this a bit...
IME the early failures seem to be about the same for incandescent, CFL, and LED (i.e., part of the "average" life span). Of course it hurts more when it's an LED, but as Angus noted, the prices on LED's are continually falling. Some of the LED's have a warranty, if that makes Bobby feel any better. The Philips bulb I was looking at for this application (5000K PAR38, 1300 lumens, 19.5W) has a 6-year warranty.
I've had to led builds in my shop for 2 years and they areon for 8-10 hrs a day still going strong. With that said what ever last as long as they say things will.
Cost Summary
Light Stand: $15
Dual Bulb Base: $9
LED Bulb (par38): $38 (x2)
Total: $100
Thanks for sharing your:
Most Excellent DIYer...and it's an affordable one at that!!
Also...
I know you won't be losing any sleep worrying about
what some folks may think (at least I never do)...'cause:
If you don't like them, don't get them.
Haters gonna hate.
Screw the haters.
Ain't that the truth - Haters gonna hate!!!
{^^Sourced from another "enlightening-thread"^^}
