Do I need rupes microfiber pads?
Mike lambert
Since Mike has probably used these more than anybody, I thought I would ask. I have the entire set and was wondering the difference between the blue foam and blue micro ?
Is it that much more aggressive?
I would like to know as well my rupes 15 is delivering tomorrow so excited to use . Haven't found anything about these mf pads
Fibers, even soft fibers are a gentle type of abrasive as they have the ability to cut the paint.​
So generally speaking, any fiber pad has the potential to be more aggressive, or offer more abrading power than a pad that has a uniform texture for a surface, like foam.
(Of course some foam pads can be very aggressive.)
If you look at the Meguiar's Microfiber DA Correction System, they put this system together to try to change the industry.
The change they want to make is to provide a way for the production detailing industry to buff out cars without inflicting swirls at the same time. We all know the problem with swirls and HISTORICALLY the root cause of swirls at dealerships and detail shops has been caused by rotary buffers.
So the Meguiar's Microfiber DA System is designed to provide correction ability without the use of a rotary buffer.
Meguiar's introduced the foam buffing pad to the world in 1965. So they have a history of knowing how to use foam buffing pads to buff paint. BUT they chose to go with a fiber pad for the system they designed to replace the use of a rotary buffer.
Think about it....
Why go with fiber pads instead of foam pads for getting good correction without using a rotary buffer?
Here is a photo of a car I am working on. This Audi had some hard clear coat and I used FG400 with the Rupes blue MF cutting pad
