WRAPT C5Z06
- Nov 12, 2009
- 12,615
I don't do a ton of cars, so I usually will start fresh(50grams size). I'm assuming I can get a lot more use other than 1 car? A dirty clay bar bugs me.
If you feel that it is getting dirty time to use a new one. I also cut up my clay bar into little pancake pieces and use them just in case I drop it I will only be losing a 1/4 of the whole bar.
Also another little tip.... if its to dirty for your paint you can move it down to using it as rim clay until its really dirty than it gets the boot.
No, the house siding before the garbage can. :xyxthumbs:Yes, in the other thread that was just like this I noted the demotion of the clay to window and then wheel use, and then for claying the inside of the garbage can...
Before or after your LSP?But I use the pressure washer on the house siding?
