cardaddy
- Nov 20, 2012
- 3,937
If your analogy is correct, why do a wipe down for a WOWA?
Simply because a WOWA sealant is a COMPLETELY DIFFERENT ANIMAL from something like M21 2.0, Menz Power Lock, or Wolfgang DGPS 3.0. The former goes on clean, wipes of fclean, and you walk away, period.
I've never seen one that was anything but clear.
Very similar process to a coating.
The latter you put on... you LEAVE on... (from minutes to hours...sometimes to the point of letting it haze) only THEN do you spend much much more time wiping it off than you'll ever spend wiping off a WOWA sealant.
I have to agree with Bob on the 'process'.
You do a test spot from start to finish, to FIND OUT what you need to do for the entire rest of the vehicle. If your buffing process isn't getting all the paint imperfections out that you WANT it to, THAT is where you adjust your 'process'.
Doesn't mean you are looking for 100% correction. Just means you are "inspecting your work" as you go. Once you reach the desired results, start to finish, all you have to do is repeat that process for every "section".
It's been said time and time again about many product lines that they have "synergy".
Meaning they play well with one another, and WOWO sealants by and large... have proven not to need thorough paint cleansing (as one needs with a coating) in order to bind, stick, cross-link with the paint. Never mind the fact that many of those WOWO sealants are pretty darned oily in their own right. :dblthumb2:
