Does Microfiber Start to Melt at 140F [my dryers low setting]
Fallguy007
My dryers low setting generates approx 140F on low. Thinking from other areas I have read that around 140F+ is where heat can start ruining microfiber???
Pretty much line or air dry my micro fiber now but still wondering: A approx what drying temp microfiber starts to suffer damage.
I've done the Air Dry thing on my dryer, but ended up having to run at least another cycle to get the towels dry.
140 seems pretty high for low. I believe my low temp setting is supposed to be like 125. Setting the machine to Delicates on Low should be pretty good.
Microfiber consists of polyester and nylon, for the most part. Both of which have melting points that are greater than 140* F.
Using microfiber in conjunction with a steamer is pretty common in the detailing industry. Well guess what? Water turns to steam at 212* F and I don't see those towels melting away.
Just use common sense and you'll be fine.
•IMO:
-No, you don’t have to worry about a
measely 140°F melting/ruining the
micro fibers in your MF-towels...that’s
just propagation of an internet myth.
•There are 6 (six) “types/grades” of
polyamide, each having their own
melting point temperatures.
-“Type/Grade 12” has the lowest
melting point = ~350°F
-“Type/Grade 4,6” has the highest
melting point = ~563°F
•Anecdotally speaking:
-The majority of the microfiber towels that
I’ve purchased are alleged to have been
made from “Type/Grade 6,6”...which has
a melting point of ~500°F.
Good point.:xyxthumbs:
http://i.imgur.com/YHEL7gy.gif
Read on Adams site and other places that if your MF are not performing to boil them for a few minutes.
If you can boil them you can dry them...
I tried boiling them once. It had no effect on restoring their absorbency. It's certainly worth a try, though.
Towels are consumables, when they stop working properly, it's time to replace them.
