Does this Process Make Sense?
bgray
Curious while using a PC.
While using Meiz IP, then xmt #3, then XMT #1.....is it nessesary to use XMT#3 in the process, or will i jsut be wasting my time? Can i skop right to XMT #1 or best stick with going from IP to 3 then 1
I recently used Menzerna power gloss, then xmt3, then P106ff polish, nice results. Then Power gloss, then P106ff ok results, all w/ 5.5 orange pad w/ rotory Power gloss and xmt3, then P106ff w/white pad, seems the finish had alot of reflection depth to me. I know that is alot of steps, but that is what worked for me, depends on the color also, try a section w/ and wo, good luck.
XMT #3 shouldn't be necessary. IP and XMT#3 sould give similar results. I've gone from SIP to XMT#2 (#2 &#1 are very close IMO) with very good results.
