ScottB
- Mar 3, 2006
- 18,803
Isn't that to just prevent rust and not to lubricate things?
says it does it all ....
How about :
1Z Einszett Ultra Gel Spray Grease
Wd40
Yes, but anything more than a thin film on the nylon rollers and any grease or oil coming out from the hinge bearing surfaces leads to that grunge we've all seen. I once spent a lot of time digging out old, caked waxy grease and grunge on a car I'd bought, with benzine and pieces of cloth over a little screwdriver. Then it was never a problem again, because instead that door lube stick wax stuff, I just used some spray oil and wiped off the excess.The liquid white lithium grease that comes in a spray can is usually best for door hinges. Spray all the hinges, rollers, ect well and then wipe any excess with a paper towel or old shop rag. Lubing door hinges is usually only needed every few years if done properly.
Wd40
WD40 is a degreaser. It actually does not lubricate. I would not recommend that at all.
Why not?!?!?!?
It would drive the lasting lubrication out of the hinges and actually dry them out after a while. It's counterproductive.
You don't want to use penetrating oil for protection in the long term.
I've used WD40 on door hinges since it was invented. It worked for me.
