DP Coating Prep Polish Question
MoBenzOwner
Just a quick easy question about DP Paint Coating Prep Polish. How long should you wait before removing the residue? Do you do a panel and remove? Do half the car, or all the car and then remove. I have never used the product before. Also see it was recommended by Autogeek to use a damp microfiber if its hard to remove. What are you all's real life experiences on best removal procedures?
Thanks!
Just polish one panel then remove. For polish, I like to use a short nap microfiber towel.
Thanks JHL88! I had just started on the car and could definitely tell it's a pretty quick drier. Thanks for confirming my thoughts.
DG SQC is the one you need to wait on before removing.
DP CPP setups quickly so I usually do 1/2 or 1/3 on the larger panels.
