Themikerobe
- Apr 21, 2017
- 35
I have a metallic dark grey car and here's the results of using Dr. ColorChip on many chips and scratches. These pictures are closeup so you notice the imperfect repair a lot more than in real life when you're looking at few square feet at once.
Dr. ColorChip has the color and metallic sheen perfect but as soon as you start to use the SealAct solution to remove the excess paint, it changes the color of the paint because it starts to expose more of the metallic bits.
This is shown here where inside the scratch, the ColorChip paint is still dark but the excess paint is much brighter as I start to remove it using the SealAct solution.
In chip #1-2 below, I didn't use the SealAct solution and instead just applied paint with a tiny brush and let it dry and you can see how close of a match the paint is but without being able to level off the chip, it's still visible. I'm sure that Dr. ColorChip on a non-metallic/pearl paint would look so good!
As you can see, with metallic paint, it totally just depends on the chip - if it's deep and small enough that the SealAct solution doesn't touch the ColorChip paint inside the chip, it'll look pretty good but if the chip is too shallow or wide, the solution lightens up the ColorChip paint inside the chip and it looks better but still visible. I did a ton of chips on my hood (not pictured) and they usually were small but deep, just like chip #1-3, which are the perfect candidates and I never notice those repairs cause they look so good and I can't even find most of them when I'm intentionally looking for them.
I've done 20 tiny chips like 1-3, 7 chips of various sizes like you see here, the 3 scratches you see here, and several chips on the roof that had rusted so I had to make them at least 1/4 of an inch (6mm) to remove the rust and I still have 90% of the paint left from the "1 dozen chip" kit! It would last anyone the life of the car unless you were doing the "squirt and squeegee method" over a decently sized area. However, I have used about 30% of the SealAct solution. Another one of those will be $12.
Overall, I definitely would buy it again. I'm so glad I heard of it. It doesn't remove most chips but it improves all chips at least enough that I don't notice them, some enough that I can't find them and scratches are still noticeable but at least they're closer to the paint color than before.
One tip I have is to cut the included cloth into many pieces and wrap them around a card like this so you get a flat surface that is less likely to reach into the chip.
Note: Some of these have the IPA/water solution I used to clean them chip or the SealAct solution residue still visible.
