cardaddy
Active member
- Nov 20, 2012
- 3,937
DO NOT PUT DRESSING ON MOTORCYCLE TIRES!
Period. I have talked to guys that did and as soon as they went to turn the bike the either dropped it or almost did, and never dressed there tires again. .......
The only product that I could remotely say might be okay on a bike tire is 303 Aerospace Protectant, as it does not have oils/lubricants that are in products like Armor All. Even if you are going to use something like 303, you should apply it on an applicator, then apply it to ONLY the part of the tire that is closest to the rim. But even then if the rubber doesn't absorb all the product and the excess wiped off/buffed off, and the tread of the tire cleaned again before riding, you still allowing the risk of the tread being slick and the rider not being prepared for it. Most, if not all, companies CAUTION against using a tire shine products on motorcycle/bike tire. Not following a CAUTION in life can cause serious injury/damage and/or death. While not following a NOTE can just make your life harder than it needs to be. Also, a lot of tire products will attract more dirt and brake dust to the tire which is something you don't want. Plus, motorcycle tires don't have a life expectancy that allows them to stay on a bike long enough to become dull and lose their natural shine; or at least they shouldn't.
As long as you clean the wheels and tires regularly, the tires should keep a nice satin/like new look to them.
:iagree:WITH :whs: +1000
One thing that'll really help is the Griot's rubber cleaner. Get it nice and clean.
Then, their vinyl & rubber dressing isn't slick at all. More of a UV protectant, and doesn't do that gloss that you normally think of as a rubber dressing.
I am NOT saying it's safe for motorcycles, but it may be something you want to lok at.
