Chris Thomas
Optimum Guru
- Dec 21, 2007
- 1,824
There won't be any issue using ocw as a drying aid other than the durability will be reduced because of the dilution with water. You can always dry and add a second coat, or if you use it at each wash interval as a drying aid you won't need to worry about longevity because you'll be adding it cumulatively.
You can use OCW as a clay Lube, but just for the clay alternatives. It will break down actual clay after kneeding a few times.
