Drying Aids 2024 – 2025
Years ago I was part of some conversations about drying aids. The question always came back to do you use a "dedicated" drying aid that adds gloss, slickness, protection? Or do you use a multipurpose product like a rinse-less wash or something that would have some cleaning ability as well? For me at the time I was trying to cut down on the Qty of product I had on hand and wanted something I could use as a drying aid as well as a quick spot clean detailer.
I have tried and used multiple products over the years. I liked the dedicated QD / sealants that added a little something extra. But at time I also wanted the cleaning ability as well so I didn't need multiple products just to do a touch up.
Currently while not popular I am using McKee's 37 SiO2 Rinse-less mixed at a QD ratio. I have tried it as a Rinse-less product and it was good, but I primarily am using it as a QD and detailer drying aid. It adds the gloss and slickness I want while also having the cleaning ability I want as well.
Used Hydrate v1 on the XR8 today.
I haven't used Hydrate on a ceramic coated surface, but on the XR8 with Wolfgang DGPS, it worked very well. In this case, I used a damp TRC Platinum Pluffle for the initial wipe, followed by another for the final buff. For each section, I found a single spray into the damp towel was sufficient, less is more.
Hydrate certainly has a very lubricated feel to it, although it doesn't quite leave the surface as slick as ADS Amplify, Bead Maker or Meg's HCD. Where Amplify and HCD can be used with a single towel, you really need that extra towel for Hydrate. In some ways, it's like a spray wax in that it needs a slight flash period before leveling any high spots with the second towel. I think that's where I struggle with Hydrate, those initial wipes produce a smeary finish that looks like it will be a nightmare to deal with but then transforms with the second wipe...................you just need to keep the faith and be patient with it. And lastly, I've always thought that this product smells a little odd, very distinctive though.
I'm going to try and keep using it on this car and see if I acclimatize to it because I really like the concept of this product.
One last note, considering Hydrate pre-dated Larry's foray into ceramic coatings, I suspect the latest Pro version was designed to work better with coatings.
Try with a twisted loop vs the Pluffle. Are you blow drying first?
Yes, blow drying beforehand.
I've used Hydrate with FTW's but I really don't like using twist loop towels if I can help it, just too grabby for my liking.
Yeah if your blow drying 1st I can see hydrate not working. Hydrate dilutes and wipes away with flooded panel
Also probably why twisted loop sticks hydrate works better on a damp panel.
If blow drying 1st it’s more like applying QD than using a drying aid.
  • Like
Reactions: DFB
I wouldn't say Hydrate didn't work for me, rather its application method takes some getting used to.
I really like twisted loop towels for drying, but I never use them with a drying aid, I like to keep them free of any products. If I use a drying aid I use a smaller standard MFs.
There is somethind odd about hydrated inert materials.
I’ve covered the drying aid topic a few times, but as always, new products come, and old products go. And while its always exciting when a new product arrives and impresses, its also nice to return to old favorites.
In basic terms, a drying aid is providing lubrication between the paint and your towel. The byproduct of using a drying aid is increased gloss, slickness and protection. When selecting a drying aid, I’m naturally aiming for that gloss and slickness improvement, but I also want something that feels lubricated and doesn’t require 15 towels to apply. In that I mean a product that can be sprayed on and then flashes away with minimal towel work. It should also be multi-surface safe, as in paint, trim, glass, rubber. And if it smells nice, even better! A product that needs special technique or multiple towels is counterproductive, and highly frustrating if it leads to streaking or hazing.
I classify drying aids into two groups –
Protective –
These are products that will boost gloss and slickness, while also leaving behind durable protection that can help maintain and prolong the integrity of your LSP (wax, sealant, coating). Products in this category would include spray waxes, spray sealants and Si02 spray sealants. The main drawback here would be streaking issues caused by excessive frequent use. I like to alternate between these two categories to mitigate this. The following are what I’m using the most at the moment.
Armour Detail Supply Amplify – Within the first 15 seconds of using this product for the first time, I knew this was a winner. Nothing comes close to offering such an easy application, it goes one and flashes away with the least amount of toweling I have ever experienced. The finished result is slick and glossy, the amazing scent seals the deal! It can also be used as often as you like without masking the LSP underneath or cause streaking issues. This is by far the product I grabbing the most at the moment.
Obsessed Garage Drying Aid – This is basically a polymer sealant that is sold by many brands, but in this case, they have removed the scent and colouring to improve chemical stability. If you like the look and feel of a waxed vehicle, this is the product for you as it exhibits that warm glow and lovely slickness that a traditional wax would deliver. It’s also very easy to use, requiring far less towel work than something like Bead Maker. While its more expensive than Bead Maker, it also goes further…………….less is more. If you don't feel comfortable buying this product (trust me, I get it), then look at Adam's Slick & Slide or Ethos Pro Shine, these have a colour and scent though.
Meguiar’s Hybrid Ceramic Detailer – This is such a brilliant product, a true gem hidden within the oversaturated Meguiar’s lineup. I wouldn’t call the protection left behind as substantial, but it certainly boosts water beading, gloss and slickness. What I love most is how easily it wipes on and flashes away to a streak free finish. If the scent was a little more modern, the product would be a knockout winner. I’d also say that its far too expensive at full price, so buy when on sale.
Wildcard – Armour Detail Supply Adapt is labelled as a waterless wash, but it works brilliantly as a drying aid due to the high lubrication factor. It does contain some Si02, so technically it belongs in this category. And its that Si02 that helps delivery the glossy, slick finish. Adapt requires slightly more towel work during application, but overall, it flashes away very nicely. And like all of their products, Adapt has a heavenly scent. In a technical sense, you could also use something like ADS Hero or Carpro ECH20 for role too.
Non-Protective –
These are products that don’t leave behind much if any durable protection, their role is simply for lubrication, gloss and slickness. These products are usually some form of detail spray, waterless or rimeless wash, and are removed by rain or at the next wash, in turn meaning you can use them as often as you like.
P&S Paint Gloss – This is a simple quick detailer that does what it says on the bottle, gloss! It’s simple to use, multi-surface safe, smells amazing and is affordable. I even use this for interior wipe downs and as an anti-static agent when dealing with stubborn carpets.
Koch Chemie All-round Quick Shine – Another quick detailer that can be used with ease. I actually got sent a bottle of this to try quite a while ago, a product that went on to surprise me immensely. I really like the unique scent, but also that simple application and the fact it can be used over and over again without adverse effect.
Meguiars Last Touch – This brand offers an endless collection of quick detailers, but this one is the best. Available in gallon or 946 ml formats, this stuff is just so fool proof that if you want something to get the job done without fuss, this will have you sorted. It has the typical quick detailer smell and colour, which means it’s a got a great overall user experience.
Wildcard – P&S Absolute mixed at the 64:1 quick detailer dilution. Using a rinse-less wash for this role makes for a really mild, simple drying aid solution that won’t cause excessive build up or streaking problems. I chose Absolute here because of the polymer-based rinse-less products, this is the slickest going without leaving behind protection.
Avoid -
While there are certainly countless drying aid options on the market, the above are the ones I've found the easiest to use and deliver the finish I'm after. The below are what I would avoid..................
In the early days of the drying aid concept, many used spray waxes. However, you may find these require more towel work to deliver streak free results, and I've noticed they feel quite grabby/sticky under the towel initially. They also don't really work on trim or rubber.
I would also avoid products like WoWo's Showstopper and P&S Dream Maker, both have a very poor user experiences and I could never make them work. I have also found the more substantial Si02 spray sealants to lack lubrication, even if they end up delivering slickness. In that respect, I tend to avoid using NV Boost v2 and P&S Defender.
Towels -
This is very subjective, so use the following as a guide.
For larger vehicles, I like to use a medium 38 x 60cm TRC Gauntlet as a primary towel, then a 40 x 40cm TRC Platinum Pluffle for a final wipe. The larger towel spreads the product and absorbs any lingering water after blowing down, the smaller towel levels any remaining drying aid.
For smaller to medium cars, I downsize the larger towel to a 40 x 40cm Microfiber Madness Chipmunk Junior, which is very similar to the Gauntlet, but in a more manageable size. I again use the Platinum Pluffle as the secondary towel.
Sadly, the Platinum Pluffle is being discontinued, so get them while you can. In the past, I have also used the FTW from TRC, which is a twist loop towel that is great for streak free results. It is however a little grabby. And for those who have issues with pink, they are available in blue and orange too.
I haven't been in for a very long time, but I haven't stopped detailing or my rampant addiction to instant detailers/spray waxes.
For phyisical and mental reasons, I been condensing down my detailing arsenal. Using either TRC's Gaunlet or Liquid8r, I'm currently using ONRv.5 plus a drying aid. The issue for me, is that when working, my DD is sitting in the sun all day, so I want some extra UV protection. I've been using OCW but have noticed some slight buildup when washing the cars every week or two. So I've now started using OPT's Waterless Wash & Shine. It gives some very comparable shine and gloss to say Girot's Ceramin Speed Shine, their Ceramic 3-1 Wax or Adam's Graphine Detail Spray, plus it contains the UV protection I'd like to have. It also doesn't seen to be the dust/pollen magnet that Beadmaker was for me. I also like that after use, I don't have to worry about soaking my towel, to prevent any SiO2 from bonding. Will it last through a rain storm, probably not, but if I'm detailing every week, not a big deal. I'm also planning to add in OPT's Ultra Ceramic Seal maybe once a month, for added protection.
Just used Griots garage ceramic Speedshine. This and OG speed shine probably my favorite QD’s still. Still plan on ordering amplify.
3D Bead It Up is a bit heavy of a product to use as a drying aid.
It’s a polymer sealant that adds gloss and slickness. And it sticks around well past the next couple of washes.
The biggest issue I had with it (besides the random streaking issues) was that it masked the properties of the underlying ceramic coating. Specifically the coatings ability to self clean itself.
I would avoid using this product as a drying aid.
I pretty much use two different drying aids. Both I would consider good and even very good. Some may turn their nose up at them but when you compare the cost you may see the light. I use a home brew made from Optimum products and I also use TEC 582. Below are the costs for each.
My Optimum home brew I mix up by the gallon and I bought the gallon sizes of the Optimum products but the same Optimum products are available in 17 oz bottles and I'll price that up as well.
The gallon of home brew consists of 100 oz distilled water/25 oz Optimum Quick Detailer/3 oz Optimum Car Wax
Gallon Optimum Car Wax $55.00 or 42 cents per oz
Gallon Optimum Quick Detailer $46.00 or 35 cents per oz
Gallon distilled water $1.28
So at the above prices the home brew can be mixed for $11.29 per gallon or 8 cents per oz.
If one buys the 17 oz bottles of Optimum products the cost is $22.19 per gallon or 17 cents per oz
For the Technicians Choice the cost is $35.56 per gallon. I use it diluted 1:1 with distilled water
Diluted 1:1 cost is $18.42 per gallon or 14 cents per oz.
I'm out of Ech20 and was thinking of trying something different. I considered ONR, but not sure I'd like it as a drying aid. I prefer something with little to nothing in it. Just a product that will make the surface slicker to dry. I've been really liking Adam's Waterless Wash. I may give that a try. Adam's Slick and Slide/OG Drying Aid and Adam's Spray Detailer are other considerations but those leave something on the surface. I'm trying to get away from constantly adding protection on to the coating or car in general.
Meguairs Final Touch is a great QD that works as a drying aid and doesn't really leave anything behind. Even if you end up hating it for that, it's a great clay lube.
I use Absolute rinseless at 1 to 64. Works great and very economical plus doesnt make my towels hydrophobic.
