Dual Action Polisher with AC 220V 50Hz Input?
maxisiri
Hi, Does anyone know if there is an available option at AG of a Dual Action Polisher with AC 220V 50 Hz input? Thanks in advance! Max
I know the Cyclo has several different options ... might need to call/email Meghan about a special order as needed.
You might need to look into step-up/down converters. Where are you located?
I am located in Argentina, I was trying to use a PC or Flex without the need of a transformer from 110V to 220V, None of the above options come with Universal Imput voltage (100-240 , 50/60 Hz)? Thanks!
Thanks, I was trying to have PC or Flex, I will try to contact Meghan and see what can she do. Thanks!
They are mad in germany and there are EU version compatible with your power. LIke stated above, Meghan can probally speacial order one.
